Question about Dyna-Glo Smart Space Living 30,000 BTU 2-Burner Propane LP Gas
How do I keep the piolet lit - Dyna-Glo Smart Space Living 30,000 BTU 2-Burner Propane LP Gas
SIT 630, model 0630535 Pilot won't stay lit when button released, even after holding in for several minutes. Good pilot flame. Pilot light had been on for several weeks and went out - now can't light.
The thermal coil that tells the gas valve to stay open when the piolet light is lit is bad. Go to the hardware store with your model and serial number, they should be able to sell you a new one. They don't cost much.
Oct 28, 2017 | Heating & Cooling
Why won't my pilot light stay lit
Try replacing the thermocouple and make sure the piolet flame is heating the thermocouple
Jul 29, 2014 | Little Giant Water Heaters
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
The piolet will lite and stay lit but the gas logs will not lite this is a milli volt type
Souns like you need A new thermopile , volts too low to open gas valve
Nov 09, 2012 | Heating & Cooling
Wall mounted 3 grate gas space heater: VIN # 41201. ser. # 1410915. Piolet light won't remain lit to be able to light grates. Also need control knob (if avail) for same model.
your pilot has dust in it. Use a drinking straw and blow air across (not into) the pilot opening. this will remove the small particles of dust that are stopping up the membrane inside the opening. THis will make your pilot flame bluer and hotter and keep the thermocouple hot enought to produce enought magnetism to hold the gas valve open.
Jan 27, 2011 | Desa International Heating & Cooling
Installed upgrade to water heater and piolet light lit fine. for a minute the flame turned yellow as condensation driped but when it stopped flame went back to blue.
New gas water heaters drip condensation the first time they are lit.
The dripping stops.
You should be fine.
Keep us posted.
You can add a comment and I will help further if needed.
Nov 03, 2010 | Whirlpool Water Heaters
I have DCS FSF-40N fryer. the piolet doesn't stay on when I release my finger it goes off I tried to change the gas valve from different brand and I only replaced small part where the electrical wire is...
You must first check to see if your pilot flame is good. If it is too weak, or not impinging properly on the thermopile, it will not stay lit. If the pilot flame is ok, the problem could be that the thermopile is weak. using a millivolt meter, test the voltage across the thermopile while the pilot is lit (you may need someone to hold the button down while you do this). You will also need to disconnect the thermopile's leads from the control while you do this. You should get about 750 millivolts across the thermopile while the flame is on it (let it heat for a while to stabilize). If your reading is too low, your thermopile may be shot and needs to be replaced. That is of course only if your flame is proper. That voltage is needed (or close) to keep the magnet open so it will stay lit when you let the button go.
Sep 04, 2009 | DCS FSF-40 Deep Fryer
The piolet light will not stay lit on a GE Profile Smart Water heater.
Make sure there is not a direct draft hiting heater. this wil always blow out flame.
It could be thermo-cuppling. If this is bad,it wont leave gas come in to keep piolet light lite. hope this helps. :)
Jul 05, 2009 | Water Heaters
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
Dyna-Glo Smart Space Living 30,000 BTU 2-Burner Propane LP Gas Logo
475 people viewed this question
Top Dyna-Glo Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Dyna-Glo Kitchen Range Expert? Answer questions, earn points and help others
