Question about Cell Phones
Find the actual temperature at the thermostat from my cell phone?
    Problem Solver:
  • 6 Answers
You don't say what kind of phone you have, but assuming it's an Android or Apple smartphone, you should understand a few things. First, your phone won't read outside temperatures by itself. You can use weather apps that download reports from local weather towers in your area, but these won't tell you how warm your home is.
How can you measure the actual temperature in your environment? You can purchase an sensor attachment that you plug in to your phone, or you can buy a thermometer/thermostat that transmits data to an app on your phone. I'm familiar with the Nest, a mobile-controlled house thermostat that works with central AC systems. It comes with an iPhone/Android app that reports on temperatures and allows a huge degree of customization in your home AC settings, but it's very expensive at over $300. Westinghouse probably makes cheaper wireless models too, but these thermostats aren't worth the money if you have a wall heater or room AC.
Me, I bought a $15 instant-read digital food thermometer from Amazon.com and take temperature readings by pushing it's on button. Cheaper, faster and easy.
Posted on Nov 18, 2014
Why does my temperture keep going up and down
Sounds like a sticking thermostat, or possibly air lock in the block. My bet would be thermostat
Jul 28, 2014 | 2000 GMC Sierra
Why is Hunter thermostat temp is wrong ?
The most likely problem is the wall on which the thermostat is mounted. The thermostat is designed to read the temperature of the space in the room, but if the wall is exceptionally warm or cold it can really throw off the actual reading.
Options might be to stuff insulation into the wall behind the thermostat, or relocate it to a wall that is more consistent in temperature with the actual temperature in the room.
May 11, 2014 | Hunter Fan Company 5/1/1 Programmable...
Aux heat comes on
If you turn your heat on and the temperature is set 3 degrees above what the actual temperature of the room, the auxillary heat will automatically come on. The auxillary heat is an electric heat strip that provides heat to your home while the heat pump is in defrost cycle or if there are extremely low temperatures outside. Try not to set the temperature more than 2 degrees above the actual temperature of the room. Hope this helps.
Jan 25, 2013 | Honeywell Programmable Thermostat Heater
How to adjust temperature
Hi, Please use your thermostat to adjust your temperature setting. Most refrigerator thermostat is come with actual temperature setting at thermostat dial but it just use range : cold-medium-off ( or 5...5..3....1..0). So for instance to get your refrigerator colder just set between medium - cold. If your thermostat defective , your refrigerator will work unpredictably. In this case you need to fix or replace the thermostat.
Regards, Jay
Feb 28, 2011 | Refrigerators
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
May 30, 2017 | Heating & Cooling
Thermastat is reading colder than the actual temperature of the room
Your question is phrased a little odd.
1) If when you say 'thermostat' - you are actually talking about a 'temperature reading' on your thermostat - then I would tell you to just get another temp measuring device and double-check the temp.
2) if howerver you are talking about the set-point of your thermostat - for example - you might have it set on 70 degrees and the room temperature is 78 - then I would say that the AC is not big enough to pull the temp down to 70 in the room, or, you have a problem with the AC that does not allow the unit to pull the temp down.
good luck!
May 02, 2010 | Sharp AF-S120FX Comfort Touch Air...
Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
The oven temperature never reaches set temperature. it's about 50 degrees lower than 375 and 75 less than 425. any ideas?
If the temperature can be controlled at this actual temperature there is very little to worry, your thermostat was manufactured with minor non-conformity in quality (meaning slightly defective product) To solve your worries, calibrate the thermostat then make a new marking to where the temperature is actual or closest to the measured one.
Nov 03, 2009 | Garland H286 Gas Kitchen Range
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Cell Phones Logo
71 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
