Question about Refrigerators
LG LRFC25750tt Er FF error- we already cleaned out fan. There was no ice buildup on the fan, cleaned off debris and dust. Plug it back in and it works for a few hours and then we get the error code
LG LRFC25750tt Er FF error- we already cleaned out fan. There was no ice buildup on the fan, cleaned off debris and dust. Plug it back in and it works for a few hours and then we get the error code again. Is it possible that this is still an issue with the fan or does this point to a motherboard issue? If it is more likely a motherboard issue is that something we can replace ourselves and how costly will it be?
  • Refrigerators Master
  • 744 Answers
Hello Nicole;
My name is Peter. I am a retired field service refrigeration technician.
It is quite a task to get to the fan. Did you really remove the back wall and access the fan? If so good for you.
I doubt the problem is the mother board. The problem is your fan, it is starting to go. Accessing the fan is the hard part. Replacing the fan motor is the easy part.
The fan motor is about $50.00. Part number 4681JB1027H.
Posted on Nov 18, 2014
BFixed
  • 104 Answers
SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Posted on Mar 11, 2008
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Posted on Jun 13, 2008
jonniewalker
  • 1031 Answers
SOURCE: Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Posted on Oct 18, 2008
SOURCE: Error Code ER FF
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it started working again. Then two days ago I got the error again. This time I decided to get inside there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out of it to get that back panel off. This includes the ice maker and the rails that the drawers slide on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my freezer one is a white screw high in the center and one was a gold screw in the little panel that the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm pull, but take care not to yank it too far... it's still connected by wires back there. When I pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never use it you should probably call someone.
Hope this helps!
Posted on Apr 21, 2009
  • 185 Answers
SOURCE: lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Posted on Aug 23, 2010
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
What does ff error mean
For LG A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Jan 06, 2018 | Refrigerators
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
What does the message "Er
Hi
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | U-Line BI-95
Refrigerator displaying error "ER FF".
This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Refrigerator is making a loud buzzing sound in the freezer compartment. We did see a Er FF error on the display. We cleaned out any extra ice/frost buildup and then reset the breaker. The display no...
check your evaporator fan maybe the fan blade hitting edges or the shaft or bushing has damage cause of buzzing sounds apply lubrication or replace bushing but before you dismantle try to off the unit.
Feb 20, 2011 | LG LFX25960ST Stainless Steel French Door...
Hi, On my LG LRFD25850ST I am getting an error
er-ff is freezer fan error not running,check for ice build up around fan,a know issue.if ice build up a new main board will be needed.or just a bad fan..
Jun 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
I have an LG LRSC26923TT Refrigerator. The display shows "Er" in the freezer temp area and "FF" in the refrigerator temp area. Nothing happens when I press any of the buttons. However, the refrigerator...
ER FF is a freezer fan error. Basically the mainboard is not receiving a feedback signal from the freezer fan motor within 65 seconds. When this happens the error code will come up and then none of the buttons will work.
You can clear out the error code by unplugging and plugging the machine back in. The error code will come back if the problem persists. Check around the freezer fan motor fan blades to see if ice buildup is interfering with the operation. Clearing out this ice may fix the issue.
If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
