Question about Microwave Ovens
I have a GE Spacemaker microwave. The fan has been coming on when door opens. It has been a little glitchy and now the microwave will not turn on at all. Lights work but microwave won't start. Fan no
I have a GE Spacemaker microwave. The fan has been coming on when door opens. It has been a little glitchy and now the microwave will not turn on at all. Lights work but microwave won't start. Fan no longer runs when door is opened
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 650 Answers
Check the door interlock switches.
Posted on Nov 22, 2014
5 Suggested Answers
  • 6 Answers
SOURCE: Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Posted on Jan 15, 2008
wiringlunati
  • 576 Answers
SOURCE: Microwave GE Spacemaker JVM1650SH05 - The light
The bulb may have blown. It is often under an access panel on the side or back that is held on with a screw or two.
Posted on Jan 26, 2010
sodeep
  • 3267 Answers
SOURCE: My GE Profile Spacemaker XL
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Posted on May 30, 2011
zappanut
  • 959 Answers
SOURCE: GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Posted on Mar 23, 2013
My ge spacemaker xl1800 light and fan turn on when door is opened. small piece of foil does not spark during this. is there an easy fix?
Kent, most microwaves will turn on the light when you open the door. As for the fan coming on, does it do that all of the time or only after you have used it for a period of time? If it does only after you have used it, you might want to check the back and the underneath of your microwave to see where the fan draws air into the unit and clean any lint built up on the vent holes. Hope this helps!
Feb 09, 2015 | GE JVM3670SK Profile Spacemaker XL1800...
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shorting
From your description the cooling fan is not running, causes! open motor winding, seized motor, or defective door switch, you will need somebody to assess
Jul 19, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave now comes on when I open the door
One of your door switches is sticking or misaligned. Eric
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have ge spacemaker microwave heats but fans dont come on .
This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Feb 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker xl1800
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Sep 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
