Question about Coffee Makers & Espresso Machines
Hi I have acquired a faema granditalia x2 coffee machine. Do I have to connect to mains water or can I put into a water source? Will it pump the water or does it have to be pressured?
  • 67 Answers
It needs a pressurised feed. Doesn't have to be very high - 0.2Bar (=6ft head) will do.
Posted on Nov 20, 2014
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: User Manual for Faema D92/A, doesn't dispense coffee, only water
This will take some time so bear with me.
The problem with the machine is most likely the solenoid valve(black or blue electrical box connected on the side of the group), for easier access remove the front panel there are about 5 screws holding it in place, 2 on the bottom and 3 on the top under-side. Disconnect or turn off the water supply. Then using a 14mm open end wrench remove the nut and the discharge pipe. Do Not remove the 4 small allen wrench screws on the brass piece connected to the machine. Now remove the electrical box over the silver pipe, and using a cressent remove the silver pipe from the brass rectangle square. Slowly open the water supply, if water shoots out then the head is clear, we will move on if not, use a pin and clean the middle hole. Check the silver pipe also there is a small plunger in there press it in if it moves freely then we are good, if not you can try soaking it in puro caff until it clears or just get a new solenoid coil. Remove the shower screen and screw in the group head, you can soak those also.
If you still cannot get water, then we will have to go deeper into the machine.
Posted on Jun 03, 2009
EsWorld
  • 1618 Answers
SOURCE: My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Posted on Jun 06, 2009
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
Faema x4 Granditalia
If you here a noise from the realys click on but display is dead then check these:
1. The Service boiler thermostat triker off and need to be reset.
2. Griding board fuse 6.3 A need to be replaced or reset.
If when you switch on you here nothing then:
1.The main switch is dead and need to be replaced or
2. The connector from power transformer is loose from overheating and need to replace the connector or connect the wires directly with each other.
May 16, 2012 | Coffee Makers & Espresso Machines
I have a Faema X2 Grand Italia C/10 NF and looking for descriptions of error codes (specifically #055). Is there a manual that gives such information?
ERROR 055 IS KTY PLUGS TO THE GROUP IN MY MANUAL,I'M A TECH AND THIS IS WHAT THE DESCRIPTION SAYS IN THE X2 TECH MANUAL... under possible causes it says either KTY disconnected or Malfunctioning card..solution is to open the machine CHECK CABLING/REPLACE KTY/REPLACE THE CARD.. hope this helps!!
May 09, 2012 | Faema Coffee Makers & Espresso Machines
We have a faema e92 but our mains water is off, can we manually fill the tank without mains water?
The machine can sack the water directly from a water tank since the water inlet hose is conected first to presure pump. Just insert the water inlet hose in a water tank, however please take care that if you leave the pump work without ay water for more than 2 minutes the pump might be destroed.
Feb 13, 2010 | Faema FA60081
I am trying to get my Faema Contessa espresso machine to draw up the water from its holding container, any ideas on how to prime its pump?
Vibration pumps usually make this when they stay long without work, sometimes they are remaining useless after this, you can try to open steam valve and to try pumping inn the water, if it does not helps, YOU MUST open the device, remove pump and blow her with compressed air few times, (they have two sensitive non return valves on the outlet). After blowing try it with water outside the device and see if she draws. If you recover the old one just put it in place and continues to work. If not than you must buy new pump
Oct 18, 2009 | Faema FA60081
Espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Apr 17, 2009 | Coffee Makers & Espresso Machines
Espresso machine problems
You may want to have a close look at the seats. There may have been irregular wear on one or more causing the leak. Try and make sure each one is back in its original location.
http://www.faema.com/eng/contatti_rete.asp
Found a manual for you (closest match) It's only for a Faema Family. Well, what the heck, it's free!
http://picasaweb.google.com/Grendelpics/FaemaFamily
Hope you come right, cheers.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
