How to fix damaged hdd's sectors ????????
I did test the hdd with HDTune and i find that some of my hdd's sectors are damaged so i tried HDD Regenerator but it doesn't do a thing. is there anyway to fix the sectors this is my S.M.A.R.T report https://drive.google.com/file/d/0BxR7NcTCL0MqVmU4bzhXVl80V2s/view?usp=sharing
  • Gman
    Gman Nov 23, 2014
    By the amount of reallocated sector-count it is conlcusive that your HD is failing. Back up your Data as soon as possible to another drive and replace the failing HD. If you can't read from the disk anymore and you need to have all the data on it you should consider HDD Regenerator. It is the ONLY piece of software around that works regenerating faulty HD's in my opinion. Saved me from disaster several times. But do not think it will really "cure" the drive. Like i said: backup your data and replace the faulty HD asap.
  • Salazar Remon
    Salazar Remon Dec 07, 2014
    thnx everyone i'd recover my data & i bouth a new hdd
    Problem Solver:
  • 9 Answers
I have tried it before and I failed, all my data was wiped and I couldn't do anything so I would recommend you to opt for an expert for your damaged HDD Data Recovery task.
http://www.manchester-datarecovery.co.uk
Posted on Dec 06, 2014
By the amount of realocated sector count it is conclusive yr hardrive is failing. Back up your data to another drive ASAP and replace the faulty drive.
If you need to get back all your data from the faulty drive and it doesn't work well you shoulod consider HDD regenerator. It is the ONLY software around that works in these instances and it has saved me Several times.
But do no think it will cure the drive !
Like i said: Back up all data & replace the drive ASAP...
Posted on Nov 23, 2014
Testimonial: "i allready recovred my data. all i want is to fix hard drive if it's possible"
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 131 Answers
Have you run chkdsk ? the bad sectors will get mapped by this and the chances of converting in good sector will increase. Do it and then after a week run it again. I am sure things will get sorted.
Posted on Nov 19, 2014
Testimonial: "that doesn't help !! the sectors are damaged physically i think."
  • 22 Answers
From what I have read a sector can be recovered only from Defrag if that doesn't work I have been told they are dead and can't be fixed
Posted on Nov 18, 2014
Testimonial: "sorry that's not making changes"
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
PC not detecting HD
HDD not Detecting only if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
Thanks..
More Tech Support Contact
http://www.techsupportmart.co.uk/
Feb 05, 2014 | Transcend StoreJet Computers & Internet
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
After using recovery disks for toshiba laptop satellite l305d i get error message 10-fa12-045d, please help??
Toshiba recovery error seem likely to be due to a failing/failed HDD. If your laptop is in warranty then visit Toshiba service center. Otherwise try this--------> I would like you to try checking the HDD with an error checking program from floppy or CD or with the drive removed from the laptop and tried in a USB external enclosure in another PC.
If the HDD itself is made by Toshiba (which seems likely) you would need a generic testing program since Toshiba don't provide their own HDD checking program.
HDTune can be used from another PC.
Have a nice Day
Oct 06, 2010 | ErrorExpert
I have recently bought a samsung SATA spintpoint 1tb hdd. The hdd gets stuck at the post. It says the name and no of the drive but nothing else. I have to reboot. Controller issues with the Sil3112A?? ...
No, the controller is just fine - but make sure that the RAID setting is disabled.
If the hard disk can't go beyond POST then it is damaged. Test it this way: put it in anther functioning pc, then install in it this free program
http://www.hdtune.com/files/hdtune_255.exe
Run the program and test the hard disk.
Oct 05, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Hi , I have a Compaq m2000 notebook, while operating on it, it gives a blue screen and reboots is it anything to do with the harddisk having bad sectors, as time while I touch the hdd portion it gives blue...
Did you try to recover your HDD. if you still getting blue screen than ned to replace HDD.
or recover HDD by pressing F11 during boot or if you have recovery dis kthan run that.
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Suppend HDD sunddenly can't detect
nahh sounds like bad pcb board of hard disk. check in bios to see if its detecting hdd.
if it is then id say try ubcd4win.com to boot pc with or without hdd to test pc and ram.
sounds like an old hdd.
Jul 22, 2008 | Maxtor Hard Drive
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
