Why dosent my micromark pir security floodlight work after going through the start up ok ?
Dip swiches set at 1&2 on. 3&4 off mode selection as shown on fitting instructions
    Problem Solver:
  • 18 Answers
This is your printer problem please contact to your printer mechanic
Posted on Nov 23, 2014
Testimonial: "not an answer to a floodlight problem"
Does anyone have the instructions which come with a micromark MM18033 500W Floodlight and WIREFREE PIR SENSOR? Thank you
Yes.
e-mail me at iclarke@rockelectronics.co.uk and I'll send you the 4 sheets f.o.c.
Sep 29, 2014 | Electrical Supplies
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
May 24, 2014 | Konica Minolta Bizhub C300 All-In-One...
Reset instructions for PIR floodlight
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
Nov 24, 2013 | Televison & Video
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
Manual on how to fax on the canon MX340
set up for fax reception the following four modes are available for receiving faxes. select a receive mode according to your needs. you can change the receive mode any time. refer to the on screen manual basic guide. A CALL RING PATTERN DETECTIVE SERVICE (DRPD/NETWORK SWICH) MAY NOT BE AVAILABLE DEPENING ON THE COUNTRY OR REGION OF USE. TEL priority mode- FAX priorty mode- FAX only mode- DRPD/network swich.
press the FAX button then press the MENU button ( the fax setting screen is displayed) use the left or right button to select RECEIVE MODE SET., then press the OK button ( the receive mode set . screen is displayed ) select a receive mode then press the OK button ( the select receive mode is sdisplayed )
Jul 12, 2011 | Canon PIXMA MX340 Wireless Office...
I have a Micromark MM23224 Alarm - I know the code to the key pad but would like some helpful information upon how I may change it to a new code - and possibly adjust the the time delay. Thank you.
If you go to micromark web page all the instructions are there, but any way press *1122# press *1 # to go into password programming mode enter 4 digit password and #, press * 0 # to exit programming mode. All done.
Dipo
Jan 03, 2011 | Vacuums
75 people viewed this question
jasbo
jasbo
