Question about Dishwashers
Need a hose for pressure cleaner must be powaforce
The arm connecter to the machine
4 Suggested Answers
muttandjeff
  • 359 Answers
SOURCE: How do I connect cleaner hose?
the hose simply is placed into the cleaner you are using ie bleach bluewolf ect iI have two just like the one you are talking about brought new and this is what the manual said to do , happy washing
Posted on Feb 01, 2009
  • 10865 Answers
SOURCE: Need hi pressure hi temp hose from the machine to the handle
call the Grainger Company. Our customer service agents are available to help you find the repair parts you need 24 hours a day, 7 days a week. Call 1-800-323-0620
Posted on May 01, 2009
  • 6468 Answers
SOURCE: I have the correct low pressure tip (same as always) cleaner won't draw through hose. Cleaner is not to thick and the hose is submerged. Help please!
there might be dried soap stuck in the fitting going to the pump try compressed air threw the fitting to the pump
Posted on Jun 09, 2012
Where can I buy spares for Powaforce tools--
the link I attatched leads you to the shop for Powaforce parts.
If they are too expensive, I would recommend searching locally for machine shops or wholesale warehouses which might have the parts you need.
Good luck & have a nice day! :)
http://www.powertoolspares.com/buy-parts/
Jul 14, 2017 | Cars & Trucks
Its actually a Zannussi DW24 bottom sprinkler not working
Here is the link for the user manual if you need it; http://www.serviceforce.co.uk/pdfs/U01296.pdf Check page 14 about cleaning the large filter and removing the lower spray arm to do so, you will probably find a blockage there that is stopping the water flow (the rotation is driven by water pressure). If there is nothing visible and cleaning in there makes no difference, first check that the water can freely run through the spray arm by simply holding it upside down and filling it with water, checking that it comes out of ALL the holes (think of them as jets) and that there is no significant limescale build up. If you are unsure or the holes seem blocked, put the spray arm in a bowl of vinegar for a half day or so and the limescale should be dissolved. There can also possibly be particles of food blocking it (rice is a favourite) which can only really be removed by a bit of persistence with a tap or hose - a garden hose in the garden is the easiest and least traumatic way. (some spray arms can be opened up - if it can be it should be fairly obvious but it is unclear from the manual and unlikely for this model). Make sure when you reassemble it that everything is exactly in the right place and tightened down properly if still no luck, then check that the water inlet hose is not kinked, the tap (if present) on the inlet hose at the wall is not half off, and the filter in the hose where it joins the machine is not blocked (to check this you have to turn off the water supply and remove the hose). Inadequate water pressure due to a restriction in the pipe will stop the spray arm spinning. The last thing to try is a complete descale - there could be limescale blocking the water in a part you can't get to - a bottle of vinegar on a hot cycle with nothing in the machine works, or you can buy "dishwasher cleaners" which are usually strong citric acid or similar that you just put in as if it was detergent and run (again empty). If you haven't done this recently it is almost certainly worth doing anyway. In Summary if there is water at mains pressure getting to the spray arm and the holes in it are clear and it is fitted properly, then it will spin. Hope this helps - please ask again if you need any help carrying out these procedures :)
Jun 23, 2007 | Zanussi 24 in. DA6153 Free-standing...
My blood pressure machine keeps giving me an error 3 it is a cvs brand
Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
Aug 14, 2014 | Health & Beauty
I bought a Parkside pressure cleaner,but I have no idea how has to be connecting?Becouse I can't connect by top water.Probably has to be connecting where is washing machine?Help me.Thank you.
You need a garden hose and outdoor spigot although it is possible to connect where the washer connects but is a real pain. You can also get an adapter to connect a garden hose to your "Tap Water" faucet but it is not recommended as you will likely break the faucet off.
Mar 12, 2011 | Garden
Doesn't seem to be travelling around the pool as good as it originally did. it is approx 15 months old
I have owned 2 phantoms over 5 years. Most likely the problem is with the hose. The Phantom's hose will invariably need repairs over time. The hose swivels break and leak causing the pressure to drop. Even one leak will cause the cleaner to slow substantially.
The pressure gauge that came with the cleaner is very helpful. It will tell you if it is a pressure issue or the cleaner itself. Check your hose swivels and joints to look for leaks. Next check the filter screens (one near wall and one in the back of the cleaner). Finally, look at the hose's connection to the wall. The culprit is likely one of the above hose related issues.
Dec 09, 2010 | Hayward Phantom Pool Cleaner Complete with...
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
Sep 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hello was wondering if you had instructions on how to replace the steering gear box on a 2001 chevrolet s10?
Removal Procedure
Notice: Do not rotate steering shaft after steering column has been removed. Damage to SIR components may occur.
Lock the steering column through the access hole in the steering column lower trim cover using the J 42640.
Remove the air cleaner assembly. Refer to Air Cleaner Outlet Resonator Replacement in Powertrain Management.Remove the intermediate shaft shield from the steering gear.Place a drain pan below the steering gear. Remove the pressure and the return hoses from the power steering gear. Cap or tape the ends of the hoses and the gear fittings in order to prevent dirt from entering the system.Remove the lower intermediate shaft coupling bolt. Draw alignment marks on the lower intermediate shaft coupling and the steering shaft. Remove the lower intermediate shaft coupling from the steering shaft. Remove the pitman arm. Refer to Pitman Arm Replacement.Remove the steering gear mounting bolts and the washers from the frame. Remove the steering gear.
Installation Procedure
Install the steering gear. Notice: Refer to Fastener Notice in Service Precautions. Install the power steering gear to the frame washers and the mounting bolts. Tighten Tighten the power steering gear to frame mounting bolts to 75 Nm (55 ft. lbs.). Install the pitman arm. Refer to Pitman Arm Replacement.Install the lower intermediate shaft to the power steering gear. Ensure that the alignment marks line up. Install the lower intermediate shaft coupling bolt. Tighten Tighten the lower intermediate shaft coupling bolt to 35 Nm (26 ft. lbs.). Install the pressure and the return hoses to the power steering gear. TightenTighten the pressure hose to 25 Nm (18 ft. lbs.) for the vehicle equipped with the 2.2L engines. Tighten the pressure hose to 30 Nm (22 ft. lbs.) for the vehicle equipped with the 4.3L engines. Tighten the return hose to 25 Nm (18 ft. lbs.). Install the intermediate shaft shield to the power steering gear. Install the air cleaner assembly. Refer to Air Cleaner Outlet Resonator Replacement in Powertrain Management. Unlock the steering column by removing the J 42640 from the steering column lower steering column trim cover access hole. Bleed the power steering system. Refer to Bleeding Power Steering System in Steering / Service and Repair.
Jul 23, 2010 | 2001 Chevrolet S-10
Wheels are not turning. water is spraying from back up valve continually so not enough pressure to put machine into action
If the pool cleaner is not running properly (too slowly or not at all), you will want to check the following things. Make sure that your wheel RPM is not less than 30. If it is, you will need to adjust the wheel RPM to make the cleaner have enough power to move properly. First check your filter screen and the debris baskets in your pump, filter, and skimmer. They could have a blockage that is causing the loss of power. Next, if you have an adjustable valve on the cleaner line, open it completely so water can flow freely to the cleaner. If that does not work, remove the blue restrictor disk from the UWF. Also, check the hoses, hose connections, and swivels for leaks that could cause loss of water pressure. If you think that it is simply your backup valve that is malfunctioning, you might need to replace it. The backup valve kit is part number G52.
Jun 12, 2010 | Polaris 3900 Sport Pool Cleaner ()
Need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
Apr 09, 2009 | Garden
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
