Bizhub 215 error c3451 how to solve this problem
I was forget power plug 220v and me use power 110v after switch on the machine now show error c3451 so how can solve
  • Office Equip... Master
  • 10,045 Answers
You need a 115 volt power supply.
Posted on Nov 19, 2014
DocuSystems
  • 10 Answers
SOURCE: i have code c3451
Power off using left side rocker switch.
Power on while holding utility counter
Press trouble reset.
Cycle power (rocker)
If it comes back immediately you need to replace the fuser.
Posted on Aug 05, 2009
SOURCE: Problem with my Konica Minolta bizhub 350
it gives the error code c3451 when i send a work to print
Posted on Aug 12, 2009
pineworks
  • 4041 Answers
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Bizhubman
  • 108 Answers
SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Posted on May 19, 2010
sinclair_cum
  • 38 Answers
SOURCE: konica minolta bizhub pro c6500 error c2452
i have checked all those parts and tested them with a multimeter and there seems to be no problem is there any other way i can overcome this problem
Posted on Nov 15, 2011
Konica-Minolta bizhub 215 giving c3451 error message?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
Malfunction c3451 detected for bizhub 250 konica minolta
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
How can i solve the problem of c3451?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
May 01, 2014 | Konica Minolta bizhub C250 All-In-One...
How to reset error c3451 in konika minolta 215
clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Feb 14, 2014 | Konica Minolta bizhub 200 Printer
Sir, My Konica Minolta bizhub 164 shows an error code c3451. How can i solve this problem.
Pressing stop button switch on the machine. It happens due to low voltage or damaged fuser bush.
Feb 13, 2014 | Konica Minolta bizhub Office Equipment &...
Konica Minolta bizhub 215 Printer error C3451& C03FF
For the C3451 Code replace the Fuser
For the C03FF there machine thinks it one model type the circuit board are set to a different model Change setting in Service mode under adjust to proper model.
Apr 01, 2013 | Konica Minolta bizhub Office Equipment &...
Konika minolta bizhub 350 Error c3451
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
Sep 16, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Getting c3451 error
There is no c3451 code in the bizhub 350 service manual.
Feb 20, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Hi there.
e replacing.
Mar 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
1,571 people viewed this question
jasbo
jasbo
