Question about Ice Cream Makers
Where can i get the following part housing forauger screw also known as extrusion chamber
How do I get a manual and recipe info on this ice cream maker when I ordered it all we received was the machine.
You might try to google the brand and model of the machine plus "owner's manual". Or go to the Brand site and look for support for the model.There might be a link. Or, go back to the seller and ask for a manual. If this was acquired on sale, chances are the manual was known to be gone.
Jun 15, 2017 | Ice Cream Makers
What is process to winterize a Taylor ice cream machine?
To winterize a Taylor 794, or almost any water-cooled Taylor machine, we need to get all of the water out of it. Follow the steps outlined here.
1. Remove the supply water hose from the water source.
2. Remove the rear panel of the machine.
3. Locate the water valves. Pictured below.
4. Have one person open 1 water valve. (You can scissor two screw drivers to take pressure off of the spring.)
5. Blow out all of the water with an air compressor until only air comes out of the drain hose.
Repeat step 4 and 5 for the other side.
046686 Water Regulating Valve 3 8
Sep 15, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Can you replace just the body part of the water value instead of having to recover and recharge the system?
Yes you can. I have never seen the charged side of the valve go bad. Remove the 4 screws (usually T-20 Torx or phillips) on the "bell housing" side, and replace everything besides that part.
046686-ntrk102vrythapb4yqnobf12-2-0_0.jpg You can order the water valve here if you need it.
Jul 25, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
How do I get the beater out of my soft serve ice cream machine model #152 12
On the front of the machine on both sides the dispensing handle there are large thumb screws (I believe 2 on your unit). Empty the product from the machine then turn the thumb screws to the left to take them off. The screws hold the face plate on the front of your machine. You will then be able to remove the face plate from the front of the unit. The beater will be in the freezing cylinder behind the face plate. You will be able to just pull it out.
May 22, 2015 | Ice Cream Makers
I CANNOT REMOVE THE DASHER TO DISASSEMBLE FOR CLEANING. THE MANUAL FOR THIS SUNBEAM ICE SHAVER SAYS TO TURN THE DASHER COUNTER CLOCKWISE UNTIL IT UNSCREWS. FROM THE UPPER HOUSING. NO WAY IT JUST KEEPS...
Laura at ifixit posted a response 4 days ago that helped me solve this problem. ifixit(dot)com/Wiki/Sunbeam_Snow_Cone_Maker_Troubleshooting
I was unable to remove that dasher following the directions. When I turned the dasher counter clockwise it just spun and spun the motor. To fix this I removed the four screws at the bottom of the machine (hidden under gray rubber foot pieces) Removed the white base and held the clear circle motor wheel steady while rotating the dasher counter clockwise -it released in just a few spins. After reassembling the product the dasher removes per manufactures directions.
Hope others can get there machine fixed. I called Rival with this fix as well in hopes others could clean their machine. Thanks again to Laura at ifixit.com!
Aug 10, 2013 | Sunbeam Slushies Snow Cone Maker Snowcone...
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
Motor runs top turns but dasher does not turn
We have used White Mountain 6 quart freezers for over 20 years and have experienced this problem with 4 separate malfunctions causing it.
1. For some reason the square shaft at top of dasher does not penetrate far enough into the motor assembly. this allows the dasher to hang free while everything else seems to function properly. We learned that if you have everything ready and want to make sure the outer freezing doesn't occur, place a 3/8 inch slice of a potato over the male spindle in bottom of wooden bucket. This jacks the can up with the dasher inside and causes the shaft to go up into the motor and work.
2. Some cans had a female plate attached to the bottom on the outside to fit down over the male spindale in the wooden bucket. This plate has been known to become detached and lost allowing the can, dasher, and everything to drop down far enough to disengage the square shaft from the motor. The potato slice will usually resolve the problem.
3. A more permanant fix is to remove the male spindale from inside the bottom of the wooden bucket and place stainless steel washers under it to jack it up, and screw it back down with stainless screws.
4. Even if the entire male spindle becomes detached and lost from the bottom inside of the wooden bucket, we have found that a healthy potato slice works as a temporary fix. While the spindle is designed to keep the can centered in the wood tub, once the ice is placed around the can, it seems to stay centered and makes ice cream.
5. We think we have improved the situation on several occaisions by tightening the screws holding the wood scrapers to the metal dasher. We try to leave a little looseness in the screws--about 1/4 inch of free play. The scrapers are designed to pull out against the inside of the can as they turn and resistance to the mix occurs, but we think it is possible for them to be so loose that they get hung slightly away from the edge of the can and once freezing starts, it continues to multiply and creates a layer of insulation leaving the inside liquid.
6. At one point some of the lids were made of a very light aluminum type material. A tab on the inside of the rim of the lid was also light metal and attached in such a manner that they could become detached or distorted so that it failed to mate up with the tab inside the can. Current models have a heavy molded lid with the tab molded into it. We never had a problem with the molded lids, but practically all the light weight ones eventually failed. As the lid turns it's tab engages the tab inside the can and turns the can with the mix in it. If the tab becomes distorted or broken, the lid will turn normally and everything looks great, but the can of mix is standing still with no stirring. Therefore a film of freezing mix forms around the inside of the can.
7. Sorry about overloading you with information, but you probably can resolve your problem with one of these fixes.
Jul 18, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Taylor Y754-27 Soft Serve Ice cream machine
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
43 people viewed this question
Top Ice Cream Makers Experts
Andrew Taylor
Andrew Taylor
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
