Question about Zebra QL 220 Plus Label Printer
I changed the Label Roll in my Zebra QL 220 Plus. After I turn on the printer it prints labels continuously and on the screen it shows "Extended Two Key". How do I get rid of this problem?
I had changed the label roll and since then it prints all the paper , even without initiating a print and does not stop until the label roll gets over. How do i overcome this issue.
  • 4 Answers
Extended two key means one of the buttons by the LCD are sticking and not releasing, you use the two key sequence to print a device configuration but if you hold in the buttons for too long r they are sticking that's when you get the extended two key error.
Posted on Nov 19, 2015
RoryMRP
  • 111 Answers
SOURCE: Zebra M4 is printing blank labels
Did you switch your ribbon as well?
Posted on Jul 07, 2009
pineworks
  • 4041 Answers
SOURCE: Zebra 4M Plus printer keeps printing same label
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 03, 2010
  • 903 Answers
SOURCE: Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
Posted on May 28, 2010
printertech1
  • 96 Answers
SOURCE: We are using the Zebra
Make sure the pause light is on and press calibrate. See if this calibration solves the problem. If not align the media sensors (top and bottom) to a position that is aligned with the least amount of preprinted data and calibrate again. Print configuration Power on while holding cancel key for 10 seconds. Use the config to help troubleshoot. Make sure the sensor type matches the media. Download user manual at zebra.com.
Posted on Nov 21, 2010
ozztech
  • 285 Answers
SOURCE: My Zebra s600 - the ink takeup reel is not
turn the printer off, press FEED, PAUSE and CANCEL at the same time, still pressing, turn the printer on, wait untill the ligths coming on, and then relese the bottuns, it gona print the sensor profile, then press the last button 4 times untill the 3 ligtns flases, it mins that the printer save the data, then turn off and on again.
Posted on Nov 25, 2010
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
How do I change the Top Of form setting
jscholten695: You have doing it in your label design software, inside printer you cant adjust this offset.
Aug 26, 2011 | Zebra QL 220 Plus Thermal Label Printer
Hello i have had problems with QL220 plus printers that feed 7 more empty labels after printing one label. I cleaned the sensors and reloaded the firmware and it's still the same. is there any fix...
akos_brachna: You must have change the label sensor value, if using the Label Vista software, you can do this. But you must have made in software, not in printer.
Jul 28, 2011 | Zebra QL 220 Thermal Label Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
I have a Zebra Stripe 600. I am trying to print a
Ok, when you say continuous...do you mean it is a roll of label material that does not have gaps in between? If it has gaps...it is NOT a continuous label and you probably have the driver settings set as continuous feed and not gap as it should be....
Call BarcodeWarehouse.biz - they will help you with any problems you have!
Aug 03, 2009 | Zebra Stripe Thermal Label Printer
When you send a label to the printer (ql420plus) - Prints the label, then a blank, then the label, then a bland until the roll ends.
More than likely you label size is not defined properly. Please make sure you have selected the correct label on the PC side.
Jul 14, 2009 | Zebra QL 420 Plus Printer
Zebra QL 220 Plus Label Printer Logo
138 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
