Question about Home
How do i install fire bricks in rayburn suprem cooker
Cooker is 29 years old has bricks on right hand side oven side and front brick
2 Suggested Answers
SOURCE: installing fire bricks in rayburn supreme
I have a rayburn - probably 1950s - with the vertical bakelite handles and am not sure whether there should be firebrick at the back of the firebox agains the water jacket.
I had a rayburn once before and thought there were. Can you help please?
Posted on Feb 22, 2011
How do you replace insulation ? It was destroyed by mice. Heater runs so hot top wires melted!
There is very little insulation on top, and to what you may consider as insulation...
the small amount of insulation is used between the header, combustion chamber/box and any wires: thermostat and limit.
if you are referring to wires at top in the front of heater, behind removable front door... Then that is due to (can be considered as insulation as well - as that is what it's supposed to do: Keep the heat in the combustion chamber/box) broken fire tile/brick!
this is common and needs to be replaced.
Call a local service provider , or remove the top assembly to access the Heat Exchanger, disconnect plumbing, then remove the H.E.
You can now see the fire brick, ANY cracks or sacrificed integrity of that brick, need replacement. The heat travels Right THRU that crack!
An easier way to visually inspect brick, would be to disconnect gas line from heater, then remove burner tray. Many wrong installations, Actually NOT To Code, will have a union for the line INSIDE the heater, close to the gas valve. Although this is not to code, it makes for a very simple burner tray removal. Anyway, once burner tray removal is complete, use a mirror and flashlight, and you can inspect brick from bottom.
Link below what that brick kit looks like...
Good Luck
Parts4heating com Teledyne Laars R0325305 Tile Kit 400
Jul 16, 2014 | Teledyne Laars Pool & Spa
Build a pizza oven in the back yard
Hi.
All you need is bricks and cement.
Use perforated bricks or regular 65mm bricks for the support. A light oven may be built on an U shaped support (you will need to make some structural considerations about the weight). Moreover the U shaped support on top requires an armed concrete slab adequate to support the chamber. If you are not sure about structural performance, build a solid support block of bricks.
Make sure that the support is adequate for the weight of the heavy chamber. If the oven is big, then lay basic foundations or build the oven straight on the ground.
For the chamber you must use refractory bricks (fire bricks). You have different choices of design. A common shaped that do not require armed concrete parts is the igloo style chamber. Leave space for the chimney on top of the chamber.
Mar 24, 2013 | Ovens
Radiators go cold after cooking programme ends
Sounds like this is wired in to the oven think you could be missing a link (elec link ) on the rayburn , try the aga rayburn web site they do have atech line
Jan 08, 2013 | Heating & Cooling
Strong smell of burning oil from chimney of rayburn
the replacement burners seems to not to be set up right. the chap should have had a analiser to make sure the settings are right.you need to call in a pro with the right kit and someone who knows how to use it. your cooker can kill when running like this do not use it
Feb 26, 2010 | Kitchen Ranges
Rayburn cookers
http://www.rayburn-web.co.uk/DirectoryList.asp?SD=Rayburn obsolete cookers/Rayburn Royal MF/
paste all that to go to the rayburn manuals download site i have seen this manual and it shows what you need
Feb 12, 2010 | Kitchen Ranges
Infrared Heater - flaming thru plaque
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Jan 15, 2009 | Procom ML060HPA Heater
Installing fire bricks in rayburn supreme
Oct 15, 2008 | Kitchen Ranges
Home Logo
74 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
