Question about Lands Phones
How can i open the outside line of a extension phone?
  • 57 Answers
Usually pressing 9
Posted on Nov 19, 2014
5 Suggested Answers
  • 10 Answers
SOURCE: Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
Posted on Dec 07, 2008
  • 112 Answers
SOURCE: Extension Phone Numbers
Press Superkey
press NO until personal keys? is displayed
Press YES
Press the desired Personal Key
make sure key is not programmed
Press Change
speed call will appear
Press YES
dial the number to be saved
include the outside access code and area code,if necessary
Press SAVE
Press SUPERKEY AGAIN TO EXIT
Posted on Jan 11, 2009
consultel1
  • 860 Answers
SOURCE: Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Posted on Sep 25, 2009
hemacom31
  • 11 Answers
SOURCE: When a call comes in from on outside line and the
you can press the message botton
Posted on Oct 03, 2009
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
How do i program my flexible buttons on my kx dt321 so i can see when other extns are busy?
Press PROGRAM press BUTTON press (0 to set a line button, press 1 to set an extension, press 2 for a outside number) Enter the number (line number or extension number or 9 followed by outside number) Press STORE
Aug 30, 2013 | Panasonic KXDT321 Phone
How do i forward calls to an outside line on Nortel M7324
You can forward an extension that is not used at all, and has the lines assigned to ring that you want to forward to an outside number. In programming have the extensions set to forward on busy to the external number using 9+ the number desired. When you leave for the afternoon, take the handset off the phone, and replace it when you return. NOTE THIS EXTENSION MUST NOT BE USED BY ANYONE -- IF THIS EXTENSION IS BEING USED AND A LINE RINGS IN IT WILL BE FORWARDED OUT.
Mar 19, 2013 | NorStar M7324 Telephone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Is there a way to disallow all outside calls and
    You could just remove the lines off of that extension:
    1.Go to extension 10 or 11
    2.Press (feature) (0) (0) (left intercom) (left intercom)
    3.Press #301
    4.Enter the extension # you want programmed.
    5.Enter the line you want removed (line 1 =01 line 2 =02)
    6.Press 2 to remove that line
    7. Repeat steps 3-6 for all lines you have on that extensions.
    Hope this helps!
    Sep 01, 2009 | Lucent PARTNER18 Corded Phone
    Stop ringing at main phones when outside calls come in.
    Here is a link to program line ringing.
    It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
    From any display phone, press Feature 11
    then enter your extension number 2 times. So if you are extension 20, do this:
    Feature11-20-20
    see if that does it.
    May 28, 2009 | Lucent PARTNER18 Corded Phone
    I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
    With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
    Apr 10, 2009 | Panasonic KX-TA824PK Phone
    Answering machine not working
    Open your TalkSwitch Management Software.
    Go to Local Extensions/Fax
    Select the extension you are using for the fax.
    Click on additional settings under the activate extensions section
    On the direct Line Access Tab put a check mark in the check box for "Use Direct Line Access on:" Select your Hunt Group or the number you have to dial to get an outside line.
    This will force this extension to not have to dial 9 or whatever number to get an outside line for dialing out.
    Jan 25, 2009 | TalkSwitch CT.TS001.124001.US...
    Stop ringing at certian phones when outside calls come in.
    http://dstech1.com/programming-line-ringing/
    Partner, all releases.
    Examples
    Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
    Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
    Programming
    To change the way outside lines or pools ring at an extension:
    1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
    2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
      • Immediate Ring - on steady
      • Delayed Ring - flashes slowly
      • No Ring - flutters quickly
    3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
    4. Continue programming or exit programming mode.
    Jan 09, 2009 | Lucent PARTNER18 Corded Phone
    Inter-Tel Axxes phone outside calls don't go to voice mail
    I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
    bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
    8e5e1dd.jpg Hope this helps someone?
    vandata1
    Sep 27, 2007 | Inter-Tel Axxess Corded Phone
    Lands Phones Logo
    23 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
