Question about Kyocera Fs-1100 Printer
The paper red light is still flashing even when i have inserted the bond paper. what could be the cause of this?
The printer is not printing and the red light is flashing and showing an error saying out of paper. how can i resolve this issue?
    Habit-Forming:
  • 91 Answers
Check paper sensor it might locked by paper scarp
Posted on Nov 18, 2014
My Xerox Phaser 6128MFP printer flashes red light after every print out....
First, when you put the paper in the tray make sure the paper holders on the side and back of the tray are positioned against the paper stack but not so much as to be snug.
Next, inside the compartment where the paper try is inserted look for a small plastic piece that hangs below the ceiling of the compartment. It should be near the front of the compartment hanging down and should swing freely backward.
Also, in the printer's paper tray settings make sure that tray is set to that size of paper you are using.
Apr 02, 2015 | Xerox Phaser 6128MFP AllInOne Laser...
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Both the green light and red light on the top of printer are flashing. There is ink in the printer but it will not print
1 st clear all pending print jobs by In run window type services.msc and the go to print spooler option just stop and restart the service.
make sure there is no paper jam or out of paper massege coming.and when you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center
Nov 24, 2009 | Epson Stylus C46 InkJet Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Kyocera Fs-1100  Printer Logo
157 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
