Question about Sewing Machines
How do I sew a rolled hem on an old elna overlocker?
I have lost my manual, and for several years have only used my overlocker to finish seams. I really need to find out how to sew a rolled hem on this 30+ year old which stills runs as well as the day I bought it.
    Novelist:
  • 143 Answers
If you put the make and model number with the word Manual, into a google search, you may be able to find a manual online. Some are free, some are copies and cost a bit.. but there are tons of them out there.
You might also try contacting Elna.. some companies, sometimes, have copies of older manuals available or might be able to direct you to a shop that could show you how it works.
Posted on Nov 20, 2014
bargainbox
  • 1388 Answers
SOURCE: Ezy_Lock 304D
This may be too small to read, if so, email via
www.bargainbox.com.au and I shall send it on........remember to only ever use the R needle, so you only have 3 threads.
To move the Rolled hem arm, you will need to release the upper knife (knob on left inside cover....push to the right and blade moves approx 6mm) so you can slide the small metal tongue to correct position for:
N = Normal
R = Rolled
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Posted on Jun 11, 2008
SOURCE: I need the manual to Euro=Pro, Model 7500, Craft N' Sew Please..
http://homeappliance.manualsonline.com/ex/thread/view/idThread/159782
This one is in 3 languages, but it is worth the read. The diagram to choose the patterns from the frony of the machine are on page 28. Hope this helps.
Posted on Sep 23, 2008
  • 3 Answers
SOURCE: Owners Manual needed for Overlocker Toyota SL 3404D
"World of Sewing" have these manuals.....you need to ask for "Toyota SL series". I got my replacement manual from them and the service is excellent. Their phone number is online if you want to ring them (UK ) Hope this is helpful to you
Posted on Dec 01, 2009
  • 1116 Answers
SOURCE: should I oil my Elna 3005 sewing machine?
Many of the new models do not require oiling.
Check the maintenace section of the manual for cleaning the shuttle area. Sometimes lint can build up and cause the machine to get noisy.
If it has been over a year since the machine was serviced, it may be time for a proffesional tune-up.
Posted on Mar 13, 2010
Overlocker elna 792d roll hem set up, please show how? To set settings?
3-thread rolled hem:
Remove left needle.
Settings as follows:
Upper looper 3-5
Lower looper 7-9
Right needle 3-5
Stitch length 1-1.5
Cutting width 3-5
Differential N
Jul 18, 2017 | Elna Sewing Machines
How to make a roll-seam on my elna overlocker 4de
Consult the owner's manual. It should have basic instructions for the settings. You may also need a presser foot for making a rolled hem.
Aug 24, 2016 | Elna Sewing Machines
How to do a rolled hem on very fine fabric
There should be a special foot for this procedure. I run a straight stitch near the edge first.
Mar 07, 2015 | Elna Sewing Machines
Why does fabric get caugh on the roll hem devise when over locking
this sounds like an overlocker/serger machine you are using? if the fabric is catching on the overlocking tongue it could be a number of factors, have you lifted the top cutting blade out of the way and forgot to put it back into place? That would be my first thought, the top and bottom blade move against each other cutting the fabric. Rolled hemming usually requires the blade to be set on about 2, or middle of its setting range, the stitch finger is pulled back out of the stitching area, top looper thread is loosened off and bottom looper thread is tightened up, resulting in the top looper thread wrapping around the edge of the fabric and pulling the cut edge down under within the seam, forming the rolled hem.
May 13, 2014 | Elna Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
Sewing Machines Logo
83 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
