Question about Grohe Home
How do I override the 100 deg. F safety check position on a Grohe, model 34436 shower faucet
  • 56 Answers
SOURCE: Shower will not get hot enough
i have no experience in fixing showers however mine once did this when i remodeled my bathroom so i called one of the guys that was workin on it and he told me that he had takin something out what looked like a gasket and said it was a scald preventer and from then on my shower has been fine hope this helped
Posted on May 19, 2009
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 21 Answers
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
  • 52 Answers
SOURCE: Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Posted on Feb 15, 2010
jyackle5
  • 8197 Answers
SOURCE: The Grohe Ladylux kitchen faucet was mounted
May I get the model # to help.
Posted on Apr 05, 2010
I want to replace an old single handle builders no-name shower, about 15 years old with a gromhix 34436 unit. My shower is tile. What steps should be expected? Is this practical?
Usually a shower stall will boarder a wall where you can access the fixture by cutting a hole in a boaring wall to get at it. If it boarders a closet or someplace thats not conspicuos, there may already be an access hole. Once you have access to the old fixture, you can remove it and, as long as the new fixture is the same size or larger, it shouldn't be that much of a problem. You may have to make the hole in the tile larger but, you should be able to do that with a 90 deg. grinder. Usually most, if not all, shower valve(single) have pretty much the same configuration. If your pies look to be in good condition, you should be able to work with piecing in the new fixture. If you cannot access the fixture from the back sie, well, thats a different story and, alo of work in redoing tile you probably won't be able to match and, a little bit of drywall work but, if you only cut the hole a sbig a you need it,you use some sort of fired decorative tile to cover the repairs spot. It's up to you.
Jun 06, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Hello: My Grohe Lady Lux Cafe kitchen faucet has become loose where is it attached to the sink. How do I tighten it back up? David
You'll have to go under the sink and look up were the faucet comes through. You'll see it's held in place by a large nut. This nut needs to be tightened. Unfortunately working in the tight space under the sink is a pain in the ****, just be patient and you should be able to tighten it. TIP: Have someone hold the faucet on top in the position you want it.
Feb 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
I cannot get the water temperature below 100 deg F
Turn the wather off to the faucet, remove the guts and make sure that there isn't any debris caught in the cold supply. Also make sure that if you have stop valves that are made into the unit, they are fully opened. Some of the new units have stops built in now and they aren't turned all the way on.
Apr 08, 2009 | Home
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Home Logo
    145 people viewed this question
    Top Grohe Home Experts
    Mike
    Donni Steen
    Are you a Grohe Home Expert? Answer questions, earn points and help others
