Question about MetroPCS Kyocera Hydro Life 4G No-Contract Cell Phone
How do I fix a broken screen on hydro life
How do I replace my broken screen
  • MetroPCS Master
  • 9,742 Answers
Google "replacement cell phone screens" and sift thru the many parts providers.
Posted on Nov 19, 2014
What is the name of my kyocera cell phone model c5215
You can call it 'Percy' :>)
Kyocera Hydro EDGE specs - Phone Arena www.phonearena.com > Kyocera phones The Kyocera Hydro EDGE is an IP57 certified phone that's both dust proof and water proof in ... This device is also known as Kyocera C5215. ... Kyocera Hydro Life;
Dec 27, 2015 | Kyocera Cell Phones
My Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is there any solution to fixing my problem? No water damage
My phone malfunctioned a few weeks ago to fix it they had ...
www.fixya.com/.../t26009599-phone_malfunctioned_few_weeks_ago_fi...
2 hours ago - my Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is ...
Kyocera hydro system recovery? ' Android Forums
androidforums.com > ... > Kyocera Hydro > Root - Kyocera Hydro
Jan 2, 2015 - I rooted my hydro and installed beats audio but now my sound does ... of something like this happening... without a working recovery like CWM.Missing: flickering ‎static
Dec 16, 2015 | Kyocera Cell Phones
I put a new drive belt on my la 175 jonh ddeere mower but its still when it get hot
hydraulic transmission is going out. you may get some additional life out of it by changing the tranny oil.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
http://tufftorq.com/products/lawn-garden/index.html
Tuff Torq Lawn Garden
May 21, 2015 | Garden
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Feb 02, 2015 | Kyocera Cell Phones
My swisher25hp-60 in.cut barely moves going forward
Was it working correctly earlier or is this your initial operation?
According to the product manual for "loss of drive":
1. Bypass linkages in the bypass position
2. Hydro belt worn, damaged, or broken
3. Idler spring loose or broken
1. Make sure that the bypass linkages are in
the drive or engaged position. Located at
the rear of the machine. Refer to decal on
the rear of the unit.
2. Replace Hydro belt.
3. Replace Idler spring
Apr 16, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Disassembly of kyocera hydro
https://www.youtube.com/watch?v=CNjEtYKRLJ0
Apr 16, 2013 | Boost Mobile Kyocera Hydro Smartphone
MetroPCS Kyocera Hydro Life 4G No-Contract Cell Phone Logo
98 people viewed this question
Top MetroPCS Cell Phones Experts
Vladimir Frolov
Lawrence Oravetz
 Brian Main
Brian Main
Are you a MetroPCS Cell Phone Expert? Answer questions, earn points and help others
