Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
I have a Bosch nexxt premium washing machine that keeps beeping when it is running. Very annoying!! Can someone tell me how to disable it? I checked to sound on the display and it is turned off.
I have a Bosch nexxt premium washing machine that keeps beeping when it is running. Very annoying!! Can someone tell me how to disable it? I checked to sound on the display and it is turned off. Thank you!!
    Habit-Forming:
  • 91 Answers
Don't ignore the warning, Check the sediment slot in the front it may full
Posted on Nov 18, 2014
SOURCE: Washer stopped. E04 beeps but won't spin or continue any cycle. Have shut off machine but only makes a strange sound.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem. Error code E04 with a full load of laundry and water in the washer. Unplug the power to the washer. Take off the round cover plate in the front right. Mine did not turn clockwise or counter-clockwise, it was completely stuck. Used two flat tip screwdrivers to carefully pry it away, without damaging anything. The plate is a hard plastic but just pliable enough.
Once removed, you will see the pump (img_0001). Unscrew the pump cover slowly. There will be water coming out, so be prepared. In my case we had a LOT of water, so I drained it gradually into a couple of large garbage bags. Wrap the bag opening tightly against the pump surround to minimize spills (img_0002).
Once all the water is gone, remove the pump cover and clean out any items trapped in the pump and in the drain from the drum (img_0003). In my case it was some loose change and a small ColorCatcher sheet. Reassemble the pump and you're done.
Also helpful:
http://www.fixya.com/support/t1589624-bosch_nexxt_dlx_washer_open_round_panel
img_0001
img_0002
img_0003
Posted on Jul 26, 2009
barkencoa
  • 3463 Answers
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Posted on Jan 23, 2010
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
Macmarkus
  • 2605 Answers
SOURCE: Bosch Nexxt Premium WFMC6400UC washer will not
Hi there, In reading your post I'm not sure I know how to approach giving a solution. Would it be possible for you to expand your post and perhaps provide more details ? Does the unit have 120vac going to it ? ( is there any lights in the display ) Does it fill with water ? ( with either hot or cold ) Do you hear the door lock ? ( you should hear a "click" when the lock engages ) Has there been any error code displayed at anytime recently ? As you can see just by saying the "washer will not wash or spin" leaves more questions rather than possible starting places to help move you toward a solution. I will watch for you to reply. Thank you for coming to fixya, I hope we/I can assist you further. Macmarkus :)
Posted on Mar 29, 2010
  • 414 Answers
SOURCE: Bosch Nexxt Premium washer shaking like crazy
Check that the w/m is level (not necessarily with a spirit, just that it doesn't rock and roll), lock the foot nuts up to the machine. Check the pump filter and outlet pipes for blockages. A machine will be noisy if it taking to long to discharge the waste water. If you have moved the w/m and are in a hard water area, you may have dislodged built up lime and that has created the problem, run a heavy duty descaler (designed for w/ms) through the w/m.
Good luck
Posted on Jul 08, 2010
Testimonial: "Good, practical advise. Thank you!"
SOURCE: Bosch Nexxt 500 Series Front Loading Washer
I have a nexxt dlx and to turn off the "acoustic signal" - select any program, lets say cotton white, then choose any TWO options hold both until a short signal is emitted, this of from the manuel and I use it
Posted on Mar 15, 2012
My bosch nexxt premium washer keeps getting check water tap light
Blocked inlet filter or kinked hose
if not then it will be your inlet valve
Feb 14, 2015 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do i get the beep at the end of the cycle to turn off
To disable the end of cycle beep on the Nexxt washer, select a program and press two of the option buttons (e.g. Stain Removal and Allergy Rinse) and hold until you hear a short beep.
Aug 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I n eed to find a scamatic for my washer
This video will show you how to change a door seal on this Bosch Nexxt Premium WFMC6400UC front loader washing machine
Jul 08, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Good luck
Jul 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
The only way is to disonnect the device from the controller board.
Sep 12, 2009 | Bosch Classixx WVF 2402 Front Load...
How to disable beeps in Bosch wfo 2442 oe
please tell me somebody how to turn off spin for bosch WFO 2442?
May 29, 2009 | Bosch Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
218 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
