Question about Staedtler Arco Compass Set
How do I use a staedtler arco compass set
How do I connect the pieces together and what are all the individual pieces names and uses
    Sergeant:
  • 231 Answers
Http://www.staedtler.us/en/products/technical-drawing-instruments/compasses/mars-comfort-551-precision-compass/
There are basically two arms to a compass. One arm usually has a point, which you can remove and reverse and or replace with different points for different paper. The other arm has a leg which can be disconnected and replaced with other legs. This arm usually holds the lead or a ruling pen. To remove the leg simply turn the thumb wheel counter clockwise ( lefty loosy, righty tighty) untl you can pulll it out. The other legs have the same fitting you slide in and then tighten the thumb wheel. You may have a very long leg you can add to make a very large circle. Hope this helps.
Posted on Feb 10, 2015
Have selected something wrong and all trains run at the same time. I can't select individual ones?
if its true and you just don't believe so , that all engines have individual addresses then its also possible you have mistakenly selected the auto cab mode on your controller , this assumes you wish to connect all your engines together and use them all to pull long train , so it powers all the engines with same throttle (just like the real thing )
May 07, 2015 | Crafts & Hobbies
Instructions use for a Alvin 916B compass
If you want to draw the biggest circle possible then join the two beams together with the black rectangular piece on the right in the picture. It has thumb wheels that tighten and loosen to grip the beam. put one trammel point on the far left and one on the far right of the joined beam. This will give you the largest radius possible.
Aug 05, 2014 | Alvin 961B Beam Drafting Compass...
A FULL set of bleeder wrenches. Where and how much? And again a FULL SET!!!
Snap on website has them individually 10 different wrenches on average off $55 a piece. dont know if that is a full set. http://buy1.snapon.com/catalog/tools.asp?tool=all&Group_ID=675713&store=snapon-store
Sep 14, 2012 | Cars & Trucks
How would i form a 50cm radius using a 25cm radius compass
Get a 25cm piece of wood then put the point of the compass at one head then put a nail thru the other head and use it as the center.
Jan 12, 2011 | Computers & Internet
What gas is best
any name brand, I use Arco, minimum octane is 89 (regular unleaded)
Oct 29, 2010 | 2001 Dodge Stratus
How to set ip of the router as static ip for my internet cafe
OK, it is NOT the "Router" that has to be set to a Staiv IP, that can ONLY be done, via your service provider, you Router/Modem, is a Slave, device, that gets it's address FROM, a DNS server, via, DHCP, now, IF your ISP assigns you a static IP, then you can do as you want. However, you can still use a dynamic, IP, and do the same, you merely have to have an individual, name, MY_Internet_Cafe.com.. whatever... & register at DNS servers, and that way whenever anyone want to connect to your website, the Name is stored on a DNS server, when the "Request" is issued. "where is so" and so..Then, the search engine, It looks up that INDIVIDUAL ID NAME, , and and regardless of actual "Address", will connect up the requester with the website.. then anyone can connect, and they don't have to know your IP address, they merely type in your "Domain Name" or Website name" and the DNS will do all the rest.
May 04, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
07 compass oil type
For mild climates or cold climates use any name brand 5W-30W oil, u may also use 10W-30W if u prefer, for longer engine life use synthetic oil of the same weight, any name brand
Apr 10, 2009 | 2007 Jeep Compass Limited
I have two updr 100's, they print fine by themselves, but they don't work together to print one after another. I have them connected properly with different scsi setting, and the second printer is...
there is a third piece you need to daisy chain the printers together. I do not remember the name off hand. I was wondering the same thing until I read one of the "full" manuals.  the piece can be found on ebay it has been going out lately for 200-300 dollars. thats why I stopped looking for the piece 2 years ago.
Feb 21, 2009 | Sony UP DR100 Thermal Photo Printer
Staedtler Arco Compass Set Logo
1,054 people viewed this question
Top Staedtler Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Staedtler Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
