Question about Gaggia Baby Espresso Machine
Why does my baby gaggia have good steam but no flow for espresso?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Turn on as if to make a coffee and then the stemer. Some time it's to do with drawing the water from the tank. Otherwise I'd descale it, that will defo fix it.
Posted on Dec 11, 2014
  • 2039 Answers
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Posted on Feb 03, 2008
EsWorld
  • 1618 Answers
SOURCE: baby gaggia steamer doesn't work
Does the machine brew hot coffee? If yes, then remove the parnello and clean the holes at the end of the steam wand. If that does not solve problem, then it is blocked where valve is connected to boiler, Try descaling machine. If no then the thermostat on the boiler has tripped and needs to be reset.
Posted on Jun 06, 2009
EsWorld
  • 1618 Answers
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Posted on Oct 21, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Posted on Nov 26, 2009
Testimonial: "Thank you very much for your quick response. I've ordered the steam switch. "
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium Espresso machine problem: steam
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Posted on Mar 05, 2010
Baby gaggia no water flow for espresso
I helped my father to fix two of these machines that had this problem. He never uses the steam, only making crema coffee all day long, every day.
It is not easy to fix, but its not complicated either. If there is no water flow from the brew group, but still steam, that means the brew group has gotten clogged with Calcium.
When you take it apart you will be amazed.
You will need a very short and fat Philips head screw driver.
Like this:
http://www.amazon.com/Short-Stubby-Screwdriver-2-piece-Set/dp/B001CWHUDA
or similar. Any hardware store will have it. 1st step is to turn the machine on its side on a soft surface to protect from scratches.
Remove the brew head and look in the brew group where you prob. haven't looked before. You will see a screen with a Phillips head screw in the middle. You need the screw driver to remove that screw. It is like almost melted in from the high heat so you need a Phillips with a fat head so as to not strip it, and a thick handle to apply a lot of torque. And you will need a bit of strength.
If you make it past this just hit me back and I'll tell you more. Or hit me if you have any other questions about this step, or at all. Believe it or not, there is more stuff past the screen.
Jul 13, 2014 | Gaggia Baby Espresso Machine
No water flow, low motor sound, weak steam
looks like your shower disc is blocked remove screw under head you well most proberly find it is blocked when looking up to light clean disc with brush until you can see through holes reassemble you will find flow and steam are better hope this helps
Dec 13, 2012 | Gaggia Baby Espresso Machine
We have just bought a secondhand baby Gaggia and we cant get the steam to come out the frother. It is an orange coloured machine .
Propably the steam pipe is blocked from dry milk. You can use a thin steel wire insert it in the pipe from bottom. If you manage to open it a little bit and start having steam then by boiling water and leave the steam pipe imerse in it it will melt the remaining dirt and by open the stem valve then the dirt will spoot out. If not then the valve is blocked or broken.
Jan 02, 2010 | Gaggia Baby Espresso Machine
Nov 26, 2009 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Oct 21, 2009 | Gaggia Baby Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
Baby gaggia steamer doesn't work
Jun 06, 2009 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
180 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
