Question about Video Cameras
Sony DXC-537P - black picture on the monitor (camera is
Hi.
I have Sony DXC-537P. This camera was removed from service few yearsago in operational condition. The camera is 11-12 years old.
Now this camera shows black picture with "Low Light" message. Colour bars and other functions (menus) are fine.
I have removed the lens, filters and prism are looking clear, CCD sensors can be seen easily.
Without lens the situation is the same, camera doesn't respond to light at all, it is completely blind.
Camera comes with CA-327 studio back, I have tested it with other camera, it is fully functional.
There are only 3 electrolytic capacitors, two are on the CCD module and another one is located on one of the cards.
I'm not strong in electronics theory, but I can solder and replace electronic elements by my own (caps, transistors, resistors).
What is a possible reason for fault in my camera?
If I'll replace caps, would it be a useful diagnostics/solution for the fault?
Thanks.
  • photorobot Dec 02, 2007
    I have changed two electrolythic caps in the CCD module, one of caps was bad.
    However, I still have the same issue.
    Might be that the CCD module is inoperative.
  • 30 Answers
SOURCE: Lens cap fault on JVC GR-D72
This is a known problem with this model. The cause has been identified by JVC as a failure of the CCD image sensor. Until October 1, 2007, repairs of units exhibiting these problems will be made free of charge at JVC Factory Service Centers.
Posted on Apr 05, 2006
techman
  • 3130 Answers
SOURCE: SONY HANDYCAM DCR-PC330E
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Posted on Apr 12, 2006
SOURCE: no image through view finder or lcd monitor
I saw a solution to this problem posted in another thread, as I was having the same problem with JVC GZ-MG40. Try tapping the top of the camcorder, about 1 inch back from the lens with the tip of a screwdriver or something else hard (key, coin, etc). It worked for me. Now I just have to wait and see how long the solution holds for.
Posted on Nov 01, 2007
kala
  • 156 Answers
SOURCE: Lens Cap Warning & Gray Distorted Display
TRY TO CHANGE THE CAPACITORS ON THE CCD BOARD ASSUMBLY AND THEN CHECK.
Posted on Jan 01, 2008
welcomejee
  • 10594 Answers
SOURCE: DCR-TRV22 Sony handycam shows black screen when recording.
Couple of questions,
Is it Sony DCR-TRV22 camcorder? please confirm model number.
Can you see fine and clear picture in playback of old recorded tapes in camcorder?
Let me know info to proceed.
Thanks.
Posted on Jun 29, 2009
When i turn my camera on to take a picture the
The black screen problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to Sony service center. If your camera is under warranty period its well and good they will replace the lens sensor for free of cost.
Thank you
Jul 19, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When i look in the viewfinder it says check diag.
Something is wrong. Call Sony Tech Support. THey should be able to help you solve the problem, or get it fixed.
Nov 14, 2009 | Sony DXC-D30 Camcorder
Black Viewing Screen DSC-W80
It seems that the problem is of "CCD IMAGER" and the good thing is that SONY repair all these kind of problem free of cost, for this please see the link Sony CCD IMAGER Support. Contact any nearest SONY SERVICE CENTRE for free repair.
Thanks for using fixya.
Jul 22, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
If the issue persists, service may be required.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
Monitor lcd
the flex wire of the lcd monitor is already cut...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Aug 16, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Sep 14, 2005 | Sony DXC-190 Camcorder
Video Cameras Logo
354 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
