Question about Canon Office Equipment & Supplies
Error 03800500-2f42 ipf 750model
I changed new printer head now its printing only black nozzle all so black coming
    Sergeant:
  • Canon Expert
  • 224 Answers
Cover-related
Posted on Nov 27, 2014
Mix-it-up
  • 832 Answers
SOURCE: brother dcp 115c : print head clogged (Red & Black not printing).
read the whole (!!!) post here:
http://www.fixya.com/support/t224245-missing_dot_in_all_colors
Its the same issue.
Posted on Oct 18, 2007
johnm329
  • 3 Answers
SOURCE: canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Posted on Jan 27, 2009
  • 79 Answers
SOURCE: I need to change the
you can solve this error code by removing the purge unit (take care of the ink).
Then you have to turn upside down the unit to check the gears. There is a white gear that moves in the ''air''. you have to re adjust the gear to transfer the move normally.
Then the problem dissapears.
Also you have to check if the motor is still moving.
Posted on Jul 20, 2009
SOURCE: Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Posted on Mar 11, 2010
cns assoc
  • 677 Answers
SOURCE: How to clean my Epson RX595 Photo All In One
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 05, 2010
HOW TO RESET ERROR E161-403E
  • To enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
first try to print nozzle check in services mode.
Scroll right to the service mode box (rightmost box) and press OK. You should then see the word 'DISPLAY'. Scroll right until you see the choice 'ADJUST' appear. Then scroll down until you see the choice 'NOZZLE 1' appear and press OK. If you haven't already loaded paper, the printer will prompt you to do so and then it will print out the NOZZLE CHECK PATTERN.
check go any nozzle no firing out ink..if ok means printhead problem need replace.
later go to maintenance menu choice replace print head.
then follow their picture image to replace the print head.
May 03, 2016 | Canon imagePROGRAF IPF605 Printer
My Canon IPF 5100 printer black ink is really fuzzy, I have to prit dark grey as I can't read the black. I have cleaned the heads and done nozzle checks, what else could it be?
If prints are coming out fuzzy this is likely to be an alignment issue. I would recommend doing some alignment tests from your printer/printer software.
Feb 05, 2013 | Office Equipment & Supplies
My print head on my canon ipf 605 wont clean??
Hello!
I have printer Canon ipf 605 , on display is displayed print head error, I have put new print head, and the problem is the same, I tryed several print heads , most of them new , and it dont want to start....again and again printhead error is displayed...
Dec 11, 2010 | Canon imagePROGRAF IPF605 Printer
Printhead check nozzles on my Canon Lp-17 and the head is realy damaged, but can print still. Every time when I print I get this message and printer doesn't want to print. How Can I ignore this print with...
can you please tell me the exact message wich IPF reports.
i.e. "change left printhead"
You can also contact me on emma.servis@gmail.com, for troubleshooting manual.
Regards!
Aug 19, 2010 | Office Equipment & Supplies
Ipf 8000 error code 003800500-2f-2f
there is no enough ink in the head managment sensor.
Go to menu, test print, nozzle check, check the grids 12 pair of grids.
Check if there are any brocken grids.
After that you have to perform head cleaning B twice or more.
If the problem still remains then replace print head.
also perform firmware update to the latest version though the official canon site
Mar 31, 2010 | Canon imagePROGRAF iPF8000 Printer
Canon IPF 700 with a hardware error 03800500-2f30. Please help
this means that you have no ink flowing from the nozzles.
1.st if possible print a nozzle check from test print menu an see the result.
the other issue i can imagine is that you replace the print head without perform firmware update.
It is very important before replacing the print head to perform firmware upgrade (cd incl. inside the head box)
Also try a head cleaning B twice or more
Oct 29, 2009 | Canon iPF700 InkJet Printer
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
493 people viewed this question
old marine
old marine
