Question about Mansfield 3-WAY ELEC CROSSOVER: 3-WAY ELEC CROSSOVER - 3-WAY ELEC CROSSOVER
What is a crossover an what does it do - Mansfield 3-WAY ELEC CROSSOVER: 3-WAY ELEC CROSSOVER - 3-WAY ELEC CROSSOVER
  • 5,670 Answers
Basically a crossover filters high and low frequency sound into separate bands and then only allows that band of frequency to reach the speaker! Uses are for feeding a sub woofer with low frequency sound and a tweeter with high frequency sound!
Posted on Nov 18, 2014
I have a set of Infinities RS8 the Crossovers are shot and both of them is it 3 way or two way crossovers
Unlikely that the crossovers are shot, almost always the drivers go to protect the crossovers. What makes you think it's the crossovers?
Aug 08, 2016 | Audio Players & Recorders
My husband and I are trying to get to our thermostat to change in my 2002 rendezvous, but there is a metal pipe in the way that we can't figure out how to remove. just behind the pipe, is a metal plate...
Hello vocalviixen,
The pipe that you referred to is the exhaust crossover pipe. Below I've included removal and installation instructions.
Also, the procedure for bleeding the coolant system is critical; if you need those instructions please post the question.
REMOVAL PROCEDURE
1. Disconnect the battery ground (negative) cable.
2. Remove the throttle body air inlet duct.
3. Drain the coolant from the cooling system.
4. Remove the inlet radiator hose from the engine.
5. Remove the thermostat bypass pipe.
6. Remove the exhaust crossover heat shield bolts.
7. Remove the exhaust crossover heat shield.
8. Remove the exhaust crossover pipe studs/nuts.
9. Remove the exhaust crossover pipe.
INSTALLATION PROCEDURE
1. Install the exhaust crossover pipe.
2. Install the exhaust crossover pipe studs/nuts.
3. Tighten the exhaust crossover pipe studs/nuts to 18 lb ft.
4. Install the exhaust crossover heat shield.
5. Install the exhaust crossover heat shield bolts.
6. Tighten the exhaust crossover heat shield bolts to 89 lb in.
7. Install the thermostat bypass pipe.
8. Install the inlet radiator hose to the engine.
9. Fill the cooling system with engine coolant.
10. Install the throttle body air inlet duct.
11. Connect the battery ground (negative) cable.
Regards,
netvan
Mar 14, 2011 | 2002 Buick Rendezvous
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
It two crossover how to use it
from the audio out of your stereo connect it to the audio in of your crossover, then audio out of your crossover connect it to the audio in of your subwoofer amplifer, and the mid or high audio out of your crossover connect it to the your mid or high freq. amplifier, take note you have two audio out from your crossover don't interchange them to utilize the normal use of your crossover unit
Jun 10, 2010 | Boss Audio Bx25 2 Way Electronic Crossover
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
How do i change my thermostat on my 2001 pontiac aztek. also how do i remove the crossover exhaust pipe to get to the @#$%^ing thing?
Exhaust Crossover Pipe Replacement
Removal Procedure
89160026
  1. Remove the exhaust crossover pipe studs/nuts.
  2. Remove the exhaust crossover pipe.
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  6. Remove the thermostat housing and gasket.
Removal Procedure
89153578
Dec 11, 2009 | 2003 Pontiac Aztek
Blown crossover in a Peavey Pro-Sub 15" speaker cab. Can this be repaired? If not, where can I get a new crossover? I went to Peavey's web site and this particular crossover isn't on there.
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
Aug 18, 2008 | Audio Players & Recorders
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Wiring 2 diamond crossovers into a sony xplode amp & cd player
The crossover wires have absolutely nothing to do with your cd player, all you do is wire your crossovers into the speaker slots on the amp and then wire your mid-range speakers and tweaters into the crossovers. All a crossover does is it splits the power from the amp to your mid-range speakers and your tweaters.
Aug 13, 2007 | Sony XM-2150GSX Car Audio Amplifier
Mansfield 3-WAY ELEC CROSSOVER: 3-WAY ELEC CROSSOVER - 3-WAY ELEC CROSSOVER Logo
567 people viewed this question
Top Mansfield Car Audio & Video Experts
xxxxxx xxx
Are you a Mansfield Car Audio and Video Expert? Answer questions, earn points and help others
