Question about Defender Home Security
The cameras intermittinely record, or don t record when activity , why,
My H.264 recorder has stopped recording--the 4 cameras still show on monitor
There are a number of possibilities. 1st: Make sure the record button is activated. (Simple I know: but check it!).2nd: Go into the menu & make sure that the camera's are all set to continuous record, not motion detect or schedule record. 3rd:Check hard drive status. If your hard drive does not appear in the hard drive section, it means it has failed & needs to be replaced.
Samuel Morris
Camtek Of NY Inc
Oct 13, 2014 | Home Security
Have no sound after recording something why?
Your only fix is to buy another camera.
The FE210 is a very low cost basic video stills camera. Although it has the ability to record video when needed it does not record audio as it lacks the hardware to do so (click here to see the Olympus model specifications which clearly show no sound recording facility listed under Movie Recording System). On your camera it's really only a free taster of video simply because the camera shares hardware with other models in the range which record both video and audio. Keeping it basic on the FE-210 keeps the price down as many users don't want to record video and so don't want to pay for unnecessary features.
I hope that my speedy answer has saved you further frustration and reassured you that you are doing nothing wrong with your camera. Please take a moment to rate my answer.
Aug 04, 2011 | Olympus FE-210 Digital Camera
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
How do i turn the flash off
Welcome to FixYa.
The FORCED OFF mode is the setting where flash is not activated in any recording condition. this mode used when taking pictures in places where the use of the flash is not permitted.
There are other 5 different mode/setting in using photo flash.
1. AUTO - flash automatically activated according to the recording condition.
2. AUTO/Red-eye reduction - flash is automatically activated according to the recording condition. It reduces the red-eye phenomenon by triggering the flash before actually recording the picture. After that, the flash is activated for actual recording again.
3. FORCED ON - use the when your subject is back-lit or under fluorescent light.
4. FORCED ON/Red-eye reduction - use this when you set the camera to PARTY MODE
5. Slow sync./Red-eye reduction - use this when you take pictures of people in front of a dark background.
I hope this solution will help you. Just send us you comments or suggestion if this solution was helpful.
Thank you for using FixYa.
Apr 08, 2011 | Panasonic Lumix DMC-FX8 Digital Camera
We are using the camera to record classroom activities. How do we record audio with our video feed? Thank you for help.
According to their website, audio functionality requires the use of their AVerVision software. And, I would surmise, a microphone connected to your computer, because it appears that this product is camera only and does not have audio recording capability.
Hope this helps.
Mar 03, 2011 | Avermedia AVerVision CP300 Digital Camera
I have a Geovision GV800 8.3.2, 16 channels and have 4 cameras installed. I tried to add 3 more cameras but they don't appear on screen, just on the Camera Record Setting, where the recording is ok. I've...
Hello
Have you tried at "Camera/Audio Instal" Menu?
Click the Configure button and select Camera / Audio Install to bring up the dialog box:
Click the Activate button and specify the cameras to be viewed
Hope that help.
Jan 09, 2011 | Geovision GV-800-16 Video Capture
When I record a video, the camera does not record the sound
This is caused by one of two things.
The first thing is that you might have accidentally activated the mute function and as a result, it cannot record the sound of the environment since the mic has been de-activated.
The second and most likely thing is that your mic is faulty and can also not record the sound in your environment.
You can try to restore the default settings and see if there is any change as the mic settings may have been altered but if it doesn't then you have to send it to an expert technician to help you change the mic.
Hope this solution helped you? Please comment if you need more information and thank you for using Fixya.com
Jan 01, 2011 | Cameras
Hello, i have a DVD-R disc, 30 minutes, 1.4 GB, handycam and we recorded some videos, one month later our recorder havent´t charge, we conected it for being charged, after that we would like to see...
I am so so sorry my friend, but like millions of other people you too have found that DVD disks for recording movies simply do not work.
The disks are 98% un-reliable for movie recordings and this is why people like myself a Pro Movie maker for 30 years keep telling the silly sods who make movie camera WE WANT TAPE cameras back, and the only one which ever worked well was 8mm tape.
I surgest you call those fools on the Sony line and tell them that you like us do NOT trust these Sony disk cams on 01256 828828 UK number.
I will be pleased if you let me know how you get on, because these disks simply are rubbish.
Jun 20, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
May 15, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Home Security Logo
46 people viewed this question
Top Defender Home Security Experts
Tom Chichester
Carlyle Houlder
Carlyle Houlder
Level 1 Expert
Jennies de leon
Jennies de leon
Are you a Defender Home Security Expert? Answer questions, earn points and help others
