HOW DO I PUT ROLLS OF PAPER IN TEXAS INSTRUMENT TI5008
IT IS A HAND HELD OLDER CALCULATOR THAT I CANNOT GET THE ROLL OF PAPER INTO
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Junk it. Its a pice of JUNK. BUY a godd Canon.
Posted on Dec 04, 2014
SOURCE: BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Posted on Oct 31, 2008
SOURCE: Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Posted on Apr 13, 2009
  • 7993 Answers
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Posted on Sep 17, 2009
RonPark
  • 855 Answers
SOURCE: Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Posted on Sep 26, 2009
SOURCE: I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Posted on Oct 06, 2009
What size paper roll is used for TI 5045sv? Can't seem to find it anywhere!
Standard 2-1/4 inch wide plain paper single copy calculator paper rolls, available at Office Depot, Reliable Office Supplies, and many other office supply stores and catalogs. Probably have them at Staples, too.
Mar 24, 2013 | Texas Instruments TI-5045 SVC Calculator
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2¼-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
We can't get the paper to go into the machine?
1. Lift the paper holder so that it extends behind the calculator.
2. Make sure the calculator is plugged into an easily accessible
electrical outlet near the calculator.
3. Move the POWER switch to ON.
4. Insert the end of the paper into the paper slot on the back of the
calculator as shown. To avoid paper jams, use quality bond paper.
5.While feeding the paper into the slot, press and hold up arrow.
Note: To prevent damaging the printer (which may void the warranty),
move the POWER switch to ON when operating the calculator without
paper.
Nov 27, 2010 | Texas Instruments TI-5045 SVC Calculator
Don't have a manual; have pulled the top off but can't figure out exactly how the paper should go in.
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Sep 08, 2009 | Texas Instruments TI-5019 Calculator
Texas Instruments TI-5032SVC
it loads in the back right under the paper roll. it just looks like a gap in the casing but it is not. it's very important
Jul 20, 2008 | Texas Instruments TI-5032 SVC Calculator
47 people viewed this question
k24674
