I have a Dyno Glo Workhorse 65,000 when i plug it in and turn on the swith nothing works have check the fuse it is ok WHAT NEXT
  • 10,263 Answers
The thermostat is next
Posted on Nov 19, 2014
roniecon
  • 6927 Answers
SOURCE: i have a dyno glo work horse kerosene heater modle
If it is a gas,thermo type heater,then the thermocouple is bad.Check and make sure the pilot lite flame is touching the tip of the thermocouple,if it is not,adjust it,to where it will.If it is not adjustable,replace the thermocouple.
Posted on Jan 15, 2010
SOURCE: Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Posted on Jan 14, 2011
  • 67 Answers
SOURCE: I HAVE A WORKHORSE 65,000
Ken's Repair Ph 7403694798 or e-mail Kcox7@columbus.rr.com
Posted on Jan 19, 2011
  • 4736 Answers
SOURCE: ihave a dyno glo heater rmc-lc20ngt nateral gas
You didn't specify whether it's a vented or vent-free heater. I suspect it's Vent-free. In which case NO!
Doing so would override any of the safety features that are built-in to shut it down if something goes wrong.
  • 76 Answers
SOURCE: my kerosene heater will not light. it is a
try to clean the nozzle with thin needle
Posted on Jan 22, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I have a wall propane Dyno-Go 30,000 BTU five bricks\r\nModel RMI 80 LPT Serial 02-01628 I need a manuel so i can turn down the pilot where can i find one and the cost.
Go to the Dyno-Go website, to see if they have a mauel available there.
Also you can type in the brand name in the search engine, and hopefully download a free one. If not, then check ebay for the maual
Nov 06, 2010 | Dyna-Glo D-E39 (LP) Wall Mounted Panel...
I have a dyno glo work horse kerosene heater modle rmckfa65-wh I TURN ON HEATER BUT IT WILL ONLY STAY RUNNING FOR 5 TO 6 SECONDS.WHAT DO I NEED TO DO TO KEEP IT RUNNING?
Jan 15, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Dyna glo workhorse heater
you need to pull top cover off. And bend the igniter in to the spray of fuel and check the gap of the ignighter to 3.5 mm and bingo should work i just bought one and had to do this to it
Jan 18, 2008 | Dyna-Glo (PPH16-LP) Utility Heater
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
