Hi,i have a control vdoo413 ,the aircon run continuosly and its icing up,never cut out
    Master:
  • 742 Answers
Icing it usually caused from low coolant.
Posted on Nov 18, 2014
I have air conditioner/heater will not come on after working for a while this morning.i alreaetdy tried reset button and doesnt help
if the aircon is running to heater and the temprature outside is really cold [ sorry do not know the exact temp] the evaperator at the back will ice up and stop the aircon from working.if this is the case you just have to wait for the ice to melt. hope this helps cheers
Oct 19, 2013 | Haier Heating & Cooling
My refrigderator made a loud noise continuosly for about 30mins and since then dose not get cold again, only the freezer compartment gets a bit cold but not cold enough to form ice.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice built up and stopped the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Whirlpool Refrigerators
01 dodge 2500 v8. Air conditioner started out strong, blowing cold air..temporarily would start blowing warm and then back to ice cold...Noticed when stopping and turning corners a hissing noise coming...
Hi. Have your car aircon evaporator cleaned. Check also the drain hose. All water should go out of the car through the drain hose. There might be something clogging up the hose that is why water will run out the floor and that causes also the aircon to work intermittently.
Have a good one!
Aug 13, 2010 | 2001 Dodge Ram 2500 Truck
Aircon condensation
Hi, If you are in the cooling posistion, you need to check the filter on this unit as when they get plugged up it will cause the evaporator coil to ice up and condensation to overflow down the front of the indoor unit. This is where the filter should be located behind the front cover. You may have to brush dirt from the coil carefully, and try and flush the drain for the condensation to run out the line or hose. This should take care of the ice problem. If you are in the heat season, let me know and we will go from there. Just look me up.
Sincerely, Shastalaker7
PS The filter may be foam. If so, just wash it out and ring it out. This will clean it.
Dec 21, 2009 | Heating & Cooling
MY AIRCON IS BUILDING UP SOME ICE
Sounds like it's low on charge, dirty coil. Is this a ductless unit or window?
Jul 26, 2009 | LG Heating & Cooling
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
Does this ice maker need a pump or is it built in zdis15css
It has a circulation pump that continuosly supplys water over a plate that forms a slab of ice on it. As the slab gets thicker the resistance values change in the ice and the machine opens a hot gas solenoid operated valve which floods the plate with heat from the condenser below. This makes the slab slide down the shoot onto a wire grid that is heated. The slab is cut into tiny little cubes and drops off into the ice bin. So yes the machine has a circulator pump. Ever so often you need to put it into the clean mode and add some nickleguard or ice machine cleaner to keep the pump and its components all happy happy.
Jun 13, 2009 | GE Monogram ZDI15C Automatic Icemaker
Aircon dont work on 2001 Pulsar. Gas ok
check pressure switch on low side on dryer in plug jump with paper clip let me know tell fixya bout me ok
May 25, 2009 | 1990 Nissan Pulsar
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
