Question about Motorola Mobility Photon Q XT897 Sprint CDMA 4G LTE Android Smartphone w/ Touchscreen Slide-out Keyboard - Black
Hi there. My Motorola XT897 won't start properly. Whenever I plug it into the charger, it charges up to the amount needed to start up, but then it shuts down again immediately after as if it h
It does this non stop, and even after trying to remove it from charging then retrying, it still does this. Any way to resolve this problem?
  • Official Brand Answer
  • 1,623 Answers
Hi Amy Ki,
I recommend you to do a factory data reset on your device:
http://bit.ly/PhotonQ-Reset, with this we can restore the start up settings.
If after the Master reset the device keep rebooting, a repair would be needed, you can contact your nearest service center using this link: http://bit.ly/CONTACT-MOTO
Regards,
Liz
Motorola Support
Posted on Nov 19, 2014
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Battery charging but laptop won't work while plugged in
The purchased is sub standard. Get a replacement from the store. N.B the fujitsu charger will work for some
Time and damage your laptop because of the higher amp
Jan 27, 2013 | Toshiba Satellite Computers & Internet
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
Hi my I phone is not charging while it is on and when switch off it start charging???
Hi -
It is not uncommon for some devices to be unable to accept a charge while in use - especially if not using the supplied charger. This is because the amount of power required to USE the device (your iPhone in this case) exceeds the amount of power provided by the charger.
If trying to make a call, you may be able to coax your iPhone to accept a charge if you shut down un-needed services such as wifi, GPS and BlueTooth radios along with turning the brightness of the display down, etc. This greatly reduces the power requirements of the phone; and if the charger is powerful enough, it will begin to slowly charge your phone. The charge rate will be significantly lower - requiring a longer time on the charger - whenever the phone is being used AND charged. Once the phone is no longer being used, the charge rate will immediately increase, since AC power no longer has to be divided between charging the battery and operating the phone lights, radio, etc. This shortens the amount of time needed to recharge, significantly.
Whenever possible, use the the supplied charger - or one with the SAME voltage, polarity, and voltage type (AC or DC). The amount of current or wattage should be the same or greater than the original. Most phones use USB connectors and are 5 Volts DC. USB standards call for between 1/2 and 1 Amp current. Since watts is equal to volts x amps, this example would represent a 2.5 (if 1/2 amp) to 5 (if 1 amp) watt charger. If you could find a higher wattage charger while still maintaining the DC voltage requirements, you would be able to use and charge the phone at the same time.
I hope this answers your charger question & good luck!
Sep 04, 2012 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
Mar 15, 2012 | Motorola Mobility Xoom
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
I am having problem with battery. After 2-3 calls, the mobile goes out of battery and then completely dead eventhough i charge it full every day.
hi, well it could be that the battery does not charge properly whenever you charge it...so, it could be that the charger is not charging the battery properly....if you can get another charger and see if that will charge it well, but if it does not work....you will then have to change the battery.
Jul 26, 2010 | Motorola Mobility MOTOROKR Z6 Cell Phone
Motorola Mobility Photon Q XT897 Sprint CDMA 4G LTE Android Smartphone w/ Touchscreen Slide-out Keyboard - Black Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
