Question about Dryers
How do i reverse the hinges on a kenmore 2649828 GAS DRYER
How do i reverse the hinges on this dryer door?
  • 94 Answers
SOURCE: kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Posted on Oct 21, 2007
  • 189 Answers
SOURCE: WHIRLPOOL DUET DRYER
I've searched around for DIY instructions, but those are exceedingly difficult to locate. It seems that Whirlpool wants you to buy their Door Reversal Kit for 11.99 in order to accomplish this.
http://www.whirlpool.com/catalog/accessory_product.jsp?parentCategoryId=375&categoryId=376&productId=895
Posted on Jan 07, 2008
SOURCE: kenmore gas dryer,belt replacement
http://repair2000.com/wpoolbelt.htm#PHOTO
Posted on May 06, 2008
dragonsthatk
  • 547 Answers
SOURCE: reversing door
you can not change the way the door opens
Posted on Feb 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 80 series Dryer: Door Light stays on and wont start
Posted on Mar 05, 2009
Kenmore 110.62622101 dryer door hinge is broke
It will be as you are facing the unit.
Sep 08, 2014 | Kenmore Dryers
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
My gas dryer Kenmore 500 series won't start when I push the start button. The light is on in the dryer chamber. The door latches and there is gas running in it.
the one side of the door switch is bad,one side controls the light when the door is open,the other side of this switch makes the unit run when the door is closed,replace the switch,or if you dont care about the door light,reverse the 2 larger connections and it will work again,but no light with door open then
Feb 11, 2011 | Kenmore 500 7953 Dryer
SWITCHING THE DOOR HINGE
if you open the door and look to the opposite side you will see to white pieces, take the screws out and they will come out, do the same with the hinges and once the screws are off the hinges lift the door open and out, switch the hinges and the white pieces. Door is now reversed. Good Luck Tim
Jan 16, 2011 | Maytag Neptune MDG9700A Gas Dryer
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
I want to reverse the day on my dryer. How do I
If this is a Kenmore Elite dryer this is possible. Just follow these steps:
1. Remove the dryer door by supporting the door while removing the screws on the hinge.
2. Lay the door face down on a good working surface like a table. Place some towels under the door to protect the surface.
3. Remove the series of screws on the INSIDE of the door and it comes apart in two halves.
4. Remove the hinge from the door and remove the plastic blank from the opposite side of the door.
5. Remove the door front plexiglas and rotate and reinstall so the door handle is on the oposite side of the door.
6. Reinstall door hinge on the opposite side of the door and reinstall plastic blank to cover where the hinge used to be.
7. Reinstall the inner door facing and screw the two halves together.
8. Pop out the small plugs on the door facing, so you can reinstall the door to the dryer. Place the plugs into the orginal screw holes on the opposite side of the door facing.
9. Reinstall door. The door will now open in the opposite direction.
Since the door switch(es) and catch are located on the top and bottom of the door facing (depending on model number) you don't have to worry about removing any switches or door catches.
This is a fairly simple process that shouldn't take you more than 30 minutes to accomplish. If you have any questions along the way, please post back and let me know. I hope this helps.
Feb 11, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore HE dryer door handle has cracked. How
Carefully remove the door from the dryer by removing the screws from the hinges and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
Searspartsdirect.com has some excellent exploded view diagrams that you can work from as well.
If you have questions, please let me know. I hope this helps you.
Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore dryer door
Yes u need a phillips head screw driver take the door hinge off and the whole door comes off there are i think six small screws around the plastic take only those off then the plastic will seperate from the metal frame then all you do is switch door hinge sides and reverse the removal no beware once switched u have a very good chance that the door will not close the same or as well as before u have to play with the adjustment of the hinge the best u can after that u can grab the door close to the hinge and very gently but firmly pull up on the door to adjust it but do beware that the hinge can and will break under to much pressure
Feb 23, 2007 | Kenmore 94832 / 94834 / 94836 Gas Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
