Question about Microwave Ovens
<!-- from fixya rte -->How do I remove the touch pad - Microwave Ovens
  • 2,374 Answers
Generally u remove the grill at top to get to top screws that hold on touch pad. Then other screws from sides or bottom or it may just lift out and up.
Posted on Nov 26, 2014
Ge profile microwave oven touchpad not working
The touch pad is more than like the problem. This is common. Try removing the ribbon connector and reinserting it back in the receptacle. If this doesn't fix the problem then replace the touch pad.
Oct 06, 2014 | GE Profile Spacemaker Over-the-Range...
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
    HELLO.
    The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
    The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
    1 Unplug the microwave from the wall outlet.
    2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
    3 Pull the grill off of the microwave.
    4 Remove the mounting screw from the top of the control panel.
    5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
    6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
    7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
    8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
    9 Plug the microwave back into the wall outlet.
    Thanks.
    Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    The touch pads of my microwave are not functioning
    In most cases if the pads are not working it must be replaced, some times the carbon tracks that are worn out can be repaired temporarily.The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control inpulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.
    The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which is not able to set the program or timing.
    There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multimeter reads a continuity. With this you can have a temporary fix
    Jul 05, 2011 | Microwave Ovens
    Starts on own F2 appears
    Unplug the oven for few minutes, say 30 minutes and then turn it on.If the problem persists, you need to replace keypad. This is a quite easy repair. You would take the grill off along the top over the door. Once off you should see the screws holding the control panel in place. Remove these screws and remove the control panel. You will now have access to replace the part. Please be aware that the unit stores lethal voltage even when unplugged.
    F2 means the touch pad has failed, the manufacturer recommends you replace the touch pad and if this fails to clear the problem replace the control board.The manufacturer recommends this but the problem normally relates to the touch pad. The control board sits just behind the touch pad so is accessible by removing the control panel.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Jun 14, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    On the touch pad numbers 3, 6, 7 and 0 dont work
    sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
    global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
    Jan 27, 2011 | Sharp R305KS Microwave Oven
    Touch pad inoperaive on one side
    about the only thing you could do is to replace the touch pad there are no repairs done to touch pads we basically just install a new one i suppose one could take one apart and try to fix it but there are no schematics that they give to the touch pad make sure before ordering a new touch pad that it is the touch pad and not the control board that has malfunctioned if you are unable to perform these tests please call a repair technician if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
    Rick
    Dec 13, 2010 | Microwave Ovens
    Reads F2 doesnt work
    F2 indicates a failure in the touch key pad. The part number for the keypad is 4393916 for white, 4393917 for black and 4393918 for almond color.
    The part runs about $77.00. It can be replaced by removing the upper grille, then removing the one screw on top of the touch pad.
    Jul 16, 2010 | Whirlpool MH7140XF Microwave Oven
    Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
    sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
    Jan 18, 2010 | Samsung Microwave Ovens
    Button panel does not work or it starts making 'pick-pick' noise
    The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
    May 18, 2009 | Sanyo EM-S9515W Microwave Oven
    Microwave Ovens Logo
    50 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
