Question about LG 42LS3450 42 inch Multi-System LED TV 110-220 volts
How do I take the stand off my lg 42ls3450?
I have taken out the 4 screws, but the base still will not detach
    Top Expert:
  • LG Master
  • 75,462 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Posted on Nov 18, 2014
Is a lg sound bar system compatable with a lg 42ls3450 tv.
Having the same problem. Can't connect the soundbar via HDMI as the LG 42LS3450 does not support Audio Return Channel over HDMI. Which means I'm only left with optical cable, but the TV doesn't seem to have that either!
Dec 27, 2012 | LG Televison & Video
Tip
DISSEMBLING AND POWER SUPPLY CIRCUIT
1. REMOVING OF REAR CABINET
1. Remove the 11 screws [1], 3 screws [2] and detach the Rear Cabinet.
2. REMOVING OF CONNECTORS, SPEAKERS, STAND COVER ASSEMBLY AND STAND ASSEMBLY
1. Remove all the connectors from all the PWBs.
2. Remove 2 screws [1] and detach the Speaker-L and Speaker-R.
3. Remove the 2 screws [2], 4 screws [3] and detach the Stand Cover assembly.
4. Remove the 4 screws [4] and detach the Stand assembly
3. REMOVING OF PWB UNITS
1. Remove the 1 screw [1] and detach the R/C, LED PWB Unit.
2. Remove the 6 screws [2] and detach the MAIN PWB Unit.
3. Remove the 4 screws [3] and detach the POWER PWB Unit.
4. Remove the 4 screws [4] and detach the INVERTER PWB Unit.
5. Remove the 1 screw [5] and detach the KEY PWB Unit..............CHECK THE LINK FOR MORE INFORMATION
Electronics Equipment Repair Center
on Feb 14, 2015 | Sanyo Televison & Video
Taken screws out and stand still wont come off
well depending how long its been together it has become seated together perhaps because after 4 screws are removed it should slide apart easily so try to lift it while holding base down
Dec 17, 2010 | LG 37LC7D 37 in. LCD HDTV
I am trying to remove the tv stand base off my 42lg30. Can someone please help!
DETACHMENT
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Loose the bolts from TV.
you can view a larger image by clicking on this link then selecting the Manual on the right hand side
the information you will need is on page 13 of the manual
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Detach the stand from TV.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Dec 03, 2010 | LG 42LG30 42 in. LCD HDTV
How many screws has to be taken out for removing from pedestal stand of lg 47" Scarlet.
The 42” has 4 screws and the 50” has 5 screws.
So, your 47” may have 4 or 5 screws on the back to hold that base on.
The pattern is:
O………O
……O…..
O……….O
If there are only 4 screws then the middle (or 5th) screw will not be there.
Good Luck.
May 19, 2010 | Televison & Video
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
I broke the Stand that my 42''LG sits in. I need to buy a new one
You can find a new stand/base assembly for this model at the following link (Please note: the screws used for the base assembly are not supplied, so you would have to reuse the old screws):
LG 42LC2D Replacement Part Stand / Base Assembly
Dec 30, 2008 | LG 42LC2D 42 in. LCD HDTV
How to remove stand
Just taken the stand off my LG 42LC2D. The stand is made of cast aluminum and has 2 long legs that insert into the base of the TV. So to remove the stand lay the TV on its screen and remove the two screws that are vertically in line next to the power socket the the 2 screws that are vertically in line under the RGB socket. The stand then pulls out from the bottom of the TV.
Dec 16, 2007 | LG 42LC2D 42 in. LCD HDTV
Remove stand from LG 50PC5D
There are four screws in the back of the TV above where the stand is. Inbetween the screws is a metal handle that pulls out. These four screws need to be removed and the metal handle pulled out. Then the TV will come off the stand.974336c.png
Oct 16, 2007 | Televison & Video
Removing stand
Most stands have 4 screws that hold them on, take out the screws and pull the stand down
Mar 10, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42LS3450 42 inch Multi-System LED TV 110-220 volts Logo
581 people viewed this question
Top LG Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a LG Health and Beauty Expert? Answer questions, earn points and help others
