Question about Crosley CDE6000 Electric Dryer
Were is the thermal fuse location and what dose it look like
    Problem Solver:
  • 21 Answers
The thermal fuse is a white block with 2 wires going to it on the back of the machine just on top of the vent on the left side if your looking at it will have to take off the panel to get access to it
were is the thermal fuse location and what dose it - 11_26_2014_5_58_25_pm.jpg
Posted on Nov 26, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
Should be located on the housing that the heating element is in. It is round and about the size of a quarter with two plug in leads. There are probably two of them. Just unplug them and take them out.
Posted on Nov 23, 2014
2 Suggested Answers
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
Daewoo dryer (thermal fuse)
-Most dryer's thermal fuse are locate on the back (Inside).
-Disconnect main power before remove the back panel cover off.
-Usually there are 3 thermals. (2 at heater element, 1 at exhausted
vent)
Good Luck
Mai
Dec 20, 2013 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Need to find fuse ,power windows stoped working.book dose not tell what fuse it is
While I'm not too familiar with this model, most cars have a thermal circuit breaker that automatically resets for the window motor circuits. They look like a square metal can and are usually located in the fuse block..these breakers can go bad from time to time
Jan 06, 2011 | 2001 Ford Taurus
Our dryer runs but dose not heat up. I checked the power supply,replaced heating element,and vacumed every thing,wash the lint filter. I have good air flow. MN#86873700
you need to check the continuity of the thermal fuses,depending on your model there might be a thermal fuse on the top portion of the heating element can it should have two red wires, disconnect the wires and check for continuity if it has none then it needs to be replaced,
Dec 05, 2010 | Kenmore Dryers
My Dry runs, how ever it dose not heat up and dry
To be sure, you need to test the element with a meter, and also check the thermal fuses and or thermostats for continuity.
Jan 18, 2010 | GE Dryers
Location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Dec 31, 2008 | Dryers
Thermal fuse
the thermal fuse is located on the heater box,the main fuse is located on the blower box,let me know-mike
Oct 07, 2008 | Kenmore 73952 Gas Dryer
Will not come on
hi thanks for the question i would check the thermal fuse located in the front of the dryer remove the front panel , and the thermal fuse is located on the air duct thanks the appliance doc
Jul 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Braun tassimo no lights
Usually when there are no lights, the AC was cut by one of the thermal fuses on the side of the water heater. One has black wires, the other has white wires. You cannot locate replacement fuses anywhere! They were custom built for Saeco (Braun). If you want, you can buy them at a 1000 qty. I pried off the aluminum cap of the thermal fuses using jewelers screwdrivers. Being careful not to change the face shape. I took the metal disc under the cap off and popped it back in opposite direction. I replaced the metal disk (BE SURE THE INSULATOR UNDER THE DISK IS PUT BACK IN, IT INSULATES THE VOLTAGE). I replaced the aluminum top, crimp two edges to hold. Then checked to be sure none of the terminals were conductive to the aluminum face.
These fuses are similar in construction to resettable thermal breakers, but the metal strap in the coffee maker does not allow room for the reset button.
Jan 19, 2008 | Braun Tassimo Espresso Machine/Coffee...
Crosley CDE6000 Electric Dryer Logo
77 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
