Question about Emerson Lc320em1 TV
I have a emerson LC320EM1F when you turn it on the green light flashes 12 or 13 times then then standby light comes on and nothing happens What will cause this
  • Emerson Master
  • 1,212 Answers
The power supply is at fault. Find diode (location) D639. It is shorted, replace with an NTE 5087A. Your TV will work now! Thanks for asking, Matt of Martins TV Repair.
Posted on Oct 29, 2015
  • 4 Answers
You will need some exp in soldering. unplug tv, press and hold power for 10 sec. to discharge any built up electricity. open tv by removing screws. look on the boards for these cylinders, they are called capacitors, look at the top of them and try to see if any are bulged normaly the tops are flat. flat is good. bulged is bad. look at the bad ones and you will see writing on them like 12v 35uf write these numbers down and go to your nearest tv repair shop and ask to buy these capacitors and hand him/her your list. once you get home its time to do some soldering unscrew the board from the tvs back and unsolder 1 capacitor at a time, to keep from getting them mixed up, then solder the new one in place. then its on to the next one. when all bad ones have been replaced put the tv back together plug up and enjoy.
this seems to be a common problem for most lcd screens. and not just tvs but also computer monitors
Posted on Feb 25, 2015
    Top Expert:
  • Emerson Master
  • 74,383 Answers
Sounds like corrupted software. A software update might be necessary. Contact any service technician. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
Electro help
Posted on Nov 18, 2014
SOURCE: I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Posted on Jan 22, 2009
dsacco86
  • 1077 Answers
SOURCE: Power will not come on. When you push the power
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you. Sorry I didn't get to you sooner.
Posted on Jul 13, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an emerson LC320EM9 HDTV it recently quit
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 01, 2009
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
  • 3 Answers
SOURCE: Emerson LC320EM1 flat TV will not turn on. Green
try turning off the power saverv feature
software problem ?
Posted on Jan 13, 2011
Emerson tv lc320em1f won't turn on and power and standby lights are on at same time not blinking. Stays on even if not plugged in until a loud whine. Was thinking capacitors but not sure.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 19, 2016 | Emerson Lc320em1 TV
What does this sound like to you?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Mar 25, 2016 | Emerson LC320EM9 32 in. LCD HDTV
Emerson lc320em1f won't turn on No standby light
Power supply board has the fuses for the TV. If one is blown you need to locate the cause. Look for burned components or capacitors that have a domed top or discolored labels.
Oct 20, 2014 | Televison & Video
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
32'' emerson tv says digital telivision then nothing
press power screen reads digital television then the power light and stand by light turn on then screen goes black
Nov 26, 2012 | Emerson Lc320em1f TV
32" emerson tv
I would suspect the power supply first Most likely bad capacitors. The main board would be suspect next as the power on command comes from the main board which switches on the run supplies.
Oct 29, 2012 | Emerson Lc320em1f TV
So I try to turn my tv on...power light goes green and then the red standby light comes on. I get nothing. Black screen.
The tv has a high voltage problem, the Emerson sets were well noted for horizontal output transistor issues, this will need a tv technician to resolve the situation.
Jan 12, 2011 | Emerson Televison & Video
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Emerson Lc320em1 TV Logo
292 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
