Question about Whirlpool Duet WFW9400VE Front Load Washer Dryer
Whirlpool duet dryer making aloud thumping noise when running?
    New Friend:
    Problem Solver:
  • 14 Answers
Have you opened it or you looking for someone to guess what it could be?
Posted on Nov 21, 2014
  • 154 Answers
SOURCE: whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Posted on Oct 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: make noise when it spins
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool duet front loader washing machine has
It appears your drive belt/coupling has failed in this instance.
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet washers started making a loud
It appears your vibration damper or drum roller has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
  • 2699 Answers
SOURCE: whirlpool duet ht washer make
you could have a broken shock but most of the time it's a damaged spider gear and you'll need to replace the washer because the part alone is 500 bucks.you're using to much detergent and it eats at the spider gear and it falls apart
Posted on Oct 21, 2010
Noise on rotation and lint filter won't go in
must be something locked in the blower. Seen it. You must remove filter chute and check for objects. DUET DRYER MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 24, 2013 | Whirlpool Dryers
My Whirlpool duet dryer was moved by the painters and when moved back makes a thundering noise when turned on coincident with the drum roation (ta...THUMP, ta...THMUP). Any ideas?
Hello & Welcome to FixYa
After reading your question, it seems that the belt has come loose causing this thumping sound. You'll have to get the belt back in place so that it works. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My Whirlpool Duet dryer is making a loud squeeling noise when drying.
Hello, the squelling noise from your dryer may be coming from the drum rollers. May need to be opened up and lubed. It can also be the idler pulley, also can be lubed. Disconnect power, remove lower panel, and see if you can isolate the noise. Oil where necessary. If you can't get to it, the drum wil need to be removed. If something is locked up or damaged, it will need to be replaced. Caution: Don't stick fingers near moving parts when running :-> Hope this helps, Rich
Jul 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help
thumping noise sounds like a flat spot on rollers, or front felt assy is falling off
Feb 21, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool Duet won't drain, won't spin and makes a light thumping noise
can help but need to know a few things first in drain do you hear any thing running and turn it back to wash and see what happens don't rate me till were done un less you just want to give me my four boxes lol
Jan 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9400VE Front Load Washer Dryer Logo
126 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
