My washing mschine is dumpng water
My clothes are getting tangled up with the agitator and wrapping around it. the machine then dumps the tub water on the floor. how do i fix this????
  • 25 Answers
Check the water pump for hose connection that hose should be the one going to the drain not the floor
Posted on Nov 26, 2014
shaggyrat
  • 1224 Answers
SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Posted on May 07, 2008
Maytag317
  • 1136 Answers
SOURCE: agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
Posted on May 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
  • 157 Answers
SOURCE: clothes get caught under
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Posted on Aug 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Agitator Dogs tangle clothes
No - The clothes will not agitate properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Hi my washing machine is tangling up all the washing around the agitator then going out of balance, stops spinning, lights start flashing and beeping? Please help me...
Make sure the agitator is down as far as it can go on the shaft. If it has worked itself partially off the shaft it can cause a gap that will cause your clothes to tangle around the agitator.
Dec 09, 2014 | Washing Machines
Clothes wrapped around the agitator at end of cycle
Can you describe the problem more better? Does it still agitate properly? Have you checked the balance of the tub? I believe you have a bent agitator shaft.
Mar 13, 2014 | Frigidaire FWSB7800DS Top Load Washer
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
Clothes get tangle around agitator
unplug the power. open the top of the washer to expose the tub. Hold on to the top layer of clothing and rotate the tub by hand in the direction that untangles the clothes.
Nov 02, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine not spinning but, water is draining. What can be the problem?
I found a pillowcase wrapped around the shaft of a calypso washer. I had to remove the agitator to get it out. Pop the nutation tower off and remove the upper agitator. f8d7c59.jpgLook in the holes for clothing. Raise up the tub to release the article. Do not attempt to remove the inner agitator.9323d88.jpg I bet you have something similar an object between the tubs. I wrote a tip about it with pictures. The water will drain because the pump has its own motor.95e6002.jpgSERVICE MANUAL
Jul 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Jan 07, 2009 | Washing Machines
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
