Question about Water Heaters
I have bought a used Rinnai R94LS natural gas tankless water heater and need to know which thermostat to buy for it?
cballard
  • 18 Answers
SOURCE: Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Posted on Dec 31, 2008
CRTN
  • 716 Answers
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
  • 11 Answers
SOURCE: BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
Q. FA - Gas leakage error, gas valve circuit not closing properly
A.
  1. Disconnect power supply cord and check wire connections on gas valve and the two connectors on the control board.
  2. Flow water out of a hot water tap above the minimum activation point of .8GPM. Measure voltage at the gas valve wire connector. The connector should measure 24VDC between the left pair of wires and 24VDC between the right pair of wires when the unit is operating. If voltage is not correct, contact Bosch Water Heating for further instruction.
  3. Gas valve may be defective, contact Bosch Water Heating for further instruction.
Q. EA - No flame ionization detected with water flow
A.
  1. Verify that all manual gas shut off valves are open.
  2. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air from gas line (especially on new installations). Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  5. Verify gas pressure meets specifications outlined in chapter 3.8. See Bulletin TWH-G2-03.
  6. Verify venting meets specifications outlined in chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  7. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If not, Call Bosch Water Heating with observations. Readings from above gas pressure test will be required.
Q. C1 - Fan rotation too low on startup
A.
  1. Disconnect power supply cord. Check wire connections on back side of fan and the two large wire connectors on the control unit. Removal of lower access panel on control unit is necessary to access connectors.
  2. Verify that supply voltage is 120VAC and is properly grounded.
  3. Verify that venting meets specifications outlined in chapter 3.6 of the installation manual. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure. Verify backdraft flapper inside flue gas collector is not stuck shut.
  4. Check gas pressure. See Bulletin TWH-G2-03. Low gas pressure may cause the fan to change its speed to meet desired temperature.
  5. Possible defective control unit. Call Bosch Water Heating for further instructions.
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: vinegar flush
You should not have to flush unless the code LC comes up. but here is the flushing diagram.
Posted on Aug 01, 2009
  • 30 Answers
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Posted on Sep 22, 2009
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
I have bought a used Rinnai R94LS natural gas tankless water heater and need to know which thermostat to buy for it? I have bought a used Rinnai R94LS natural gas tankless water heater and need to know...
Plumbcentre have a parts desk for gas appliances.
most appliances are available to view in an exploded view with clear identification of parts.
However when it comes to gas, I strongly advise on using a GASSAFE engineer
Nov 18, 2014 | Water Heaters
Our rinnai R94LS will shut off after running several minuets and shows error code#10. I'll turn it off for several minutes and turn back on, run system for several minuets and it will shut off again and...
Tankless computer is not working.
Error 10 is blocked flue or inadequate air supply. Or failed PC motherboard, or failed sensor etc.
Get more fresh air to unit. Check if bird built nest on flue pipe. If flue exits side of house, look for obstructions nearby that can slow the exit of poisonous vent byproduct into the air you breathe. For example trash cans and boxes or parked car etc.
http://waterheatertimer.org/pdf/Rinnai-installation-and-error-codes.pdf
Call service technician who is qualified to work on tankless computer. This will be a well-seasoned veteran of computer technology and plumbing expertise ... a plumber who knows how to fix computers lol.
This person will catch unit up on required yearly maintenance, and check specialized operation conditions needed for tankless computers to function properly.
If tankless computer is older than 5 years, then compare it to your 5-year old laptop, and assume same level of glitches and problems.
Solve any tankless problem yourself, today, for $385 by installing tank type heater from local box store:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 29, 2013 | Rinnai Water Heaters
Water temperature turns suddenly cold
is there a dedicated gas supply line to the heater?
gas supply is critical to tankless water heaters.
they use a large amount of natural gas.
Aug 12, 2013 | Rinnai Water Heaters
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Leaking relief valve
1) Copy following link for troubleshoot and replacement TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Add comment and say what you find
Dec 24, 2012 | Rinnai R75LSe Natural Gas Tankless Water...
Im looking for the best option to get a Rinnai unit that would supply water at 30c or just below. i was going to buy the REU 55RT but looking at the manual i dont know how low the temp can get
Most tankless are preset to 120 degrees F.
30 degrees C is 86 degrees F.
If you want adjustable product, then tankless is not best choice.
Tankless are high tech gadgets with multiple interrelated parts controlled by sensors feeding information to control board. Everything internal and external has to be working correctly for tankless to work at all.
Most tankless brands do not suggest self-install, or self-adjustment, or any adjustment for reason given above.
You would be better off buying typical tank-type gas or electric and then thermostat adjustment is simple.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
http://waterheatertimer.org/pro-n-con.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 23, 2011 | Rinnai Digital Remote Water Heater Control...
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
55 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
