Question about GE Profile PV977NSS 36" Island Chimney Hood with 450 CFM Internal Blower, Vertical Exhaust, Variable Speed Fan Control and Dual HaloCooktop Lighting
We have a 7,11" ceiling and installed the GE Profile 36" range hood (PV977NSS) at the recommended 24" above the range. But it,s at eye level and presents a danger to anyone in the area. Can the vert
Danielprice32@gmail.com
ngafm
  • 166 Answers
SOURCE: GE Profile gas range
hello dreeden5
Ngafm at your service,
You have a GE Profile oven range. I and you just cleaned it and the pilot light on all four burners continues to click on and off.
It sounds like the gas line or the gas valve, have some debris in them!
They need to be evacuated by an experienced tech.
This time you need service.
Bless You ngafm
Please give me a good rating at this sight before you leave!
Thank You
Posted on Sep 11, 2008
  • 111 Answers
SOURCE: GE Profile JGSP32GEV3BB slide in range - regulator went bad #WB19K5020
"GE makes garbage" that's what a lot of independent servicers says about brands they can't become authorized to work on because GE for instance has factory service. What makes the repairman think the regulator is bad? It is highly unlikely to be the case.
Posted on Jan 02, 2009
  • 70 Answers
SOURCE: GE JSP39 range; front right burner eye doesn't work at all
there are two tests to chk which is bad,wether it is the control switch or the elemnt.disconnect the power to stove and open the top and disonnect the wires from elemnt and chks the continuity of the elemnt coil with a multimeter.if the meter does not read continuity then elemnt is bad.to confirm this connect the wires back to the elemnt and plug the unit to power, turn on the switch to high position and read the voltage coming to elemnt.it should be 240 volts.if u read that voltage, then for sure element is bad.if every thing is opposite to this then it is the control switch which is bad.
Posted on Aug 21, 2009
SOURCE: ge profile range door wont close
My GE Oven door won't close all the way. I just bought the house so i do not know what caused the problem. Please help
Posted on Sep 03, 2009
  • 744 Answers
SOURCE: I would like to get a replacement filter for my
A few options for you:
These filters are usually washable. Unless the media is falling apart, they can be washed by hand with hot water and a good dishwashing liquid.
These filters have a metal media for fire safety and your local hardware or home improvement store will usually have this variety of filter media for a few bucks. You can then cut it to size and replace the media in the frame. If the frame is hot, this might not be an option.
You can contact the GE vendor (they may have a website) and find out where you can order a filter assembly,
Posted on Dec 18, 2009
Jxb37 won't lower
My unit always goes up. Sometimes it doesn't go down. Then, after some time it goes down. Could it be the capacitor is bad?
Mar 10, 2014 | GE Profile JVB67HWW 36" Telescopic...
Minimum height
Many range hood manufacturers recommend 30" to 36" above the range though one site says as low as 24 inches
Nov 28, 2013 | Kitchen Ranges
I'm looking for an intall manual for an LG Gas Cook top Model # LCG3691ST, and a LG Fridge # LMX21984ST and a LG wall oven #LWS3081ST. Can you please help?
Hello Lola,
I understand that you need the installation documents for a few LG appliances you have. I would be glad to assit you in this endeavor.
LG Gas Cook Top LCG3691ST -
Product (36")
Width 36"
Height 3 34"
Depth 21 11/16"
Cutout (36")
Width 33 15/16"
Depth 19 11/16"
Minimum Spacing (30", 36") 1" Back, 11 13/16" Left, 11 13/16" Right
Net Weight 44lbs (30"), 50lbs (36")
LG Fridge LMX21984ST - http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LMX21984ST&matchedModelCode=1000004146&searchEngineModelCode=LMX21984ST&targetPage=support-product-profile&initialTab=documents
LG Wall Oven LWS3081ST - http://www.lg.com/us/appliances/pdf/LWS3081STss.pdf
The above gives you the need deminsions to install the units.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Kitchen Ranges
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Wouldn't raise
The GE repair guy came and fixed our vent! He opened up the cover and found that the pivot arm was above where it was supposed to be. It had gotten dislodged or something. He replaced the pivot arm with a new one, Part #WB02X10303, which is supposed to be a new design that won't get off track so easily. Works great now.
Oct 03, 2008 | GE Profile JVB67HWW 36" Telescopic...
30 INCH TELESCOPING DOWNDRAFT VENTILATION UNIT
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Sep 04, 2008 | GE Profile JVB67HWW 36" Telescopic...
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
GE Profile PV977NSS 36" Island Chimney Hood with 450 CFM Internal Blower, Vertical Exhaust, Variable Speed Fan Control and Dual HaloCooktop Lighting Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
