Any suggestions on most likely problem?
Burner gets nice and hot, but shuts down before circulation fan comes on. Burner status lights flash.
  • 148 Answers
It should tell you that flashing code of it problems
Posted on Nov 23, 2014
5 Suggested Answers
SOURCE: BURNER STATUS LIGHTS START FLASHING, SHUTS DOWN!
Not sure exactly what is meant by half way it shuts off. My furnance wouldn't heat to 68 degrees from a setting of 63 degrees on the setback thermostat without shutting down several times with a single flashing led. It would reset after an hour or so until it finally reached the 68 degrees. The problem turned out to be the tube that drains the water from the blower assembly. It had a belly in the middle which would cause the water to sit and block the airflow sensor for the gas value. Lifted tube to allow proper drainage to correct.
Posted on Dec 24, 2008
  • 79 Answers
SOURCE: main blower stays on, burner fan on intermitantly,
All gas furnaces have a fan control of some sort. Either a mechanical fan control where there is a temperature probe that reaches into the heat exchanger compartment thru a hole in the panel that separates the control part of the furnace(this would be the front of the furnace where all the controls are) from the heat exchanger. This type of control is either a small black plastic control about 4 inches by 2 inches and about 1 1/2 inches thick secured to the panel with 2 screws. Or it is a slightly larger silver colored control that should have a pull off cover. It may say Honeywell on it. Either way the control will need replacing.
The other type of fan control is a solid state control board. This will most likely be located in the indoor fan compartment. It should be located under a covered control box. The box with all the wires going into it. This board will also need to be replaced if your furnace uses this type of fan control. You will need to bring your furnace model and serial number to a dealer that sells your brand of furnace or go online to a parts dealer that carries parts for your furnace. Hope I was of help to you! Good luck!
Posted on Nov 28, 2009
heatman101
  • 43501 Answers
SOURCE: main burner comes on and
There could be a couple of different things happening...
The most likely is that the high limit switch is bad and the flame causes it to bring on the blower and then shuts the flame down also...this could be because the high limit is bad or because the vent is blocked and the flue gases are not venting...
Could also be a bad/dirty flame sensor, but that is not as likely...
I would checkout the high limit and find out what is going on there...
heatman101
Posted on Feb 02, 2011
  • 4736 Answers
SOURCE: I have a cozy wall
The heat sensor, that turns the blower ON at the right temperature has failed and needs to be replaced.
Posted on Apr 26, 2011
Mitsubishi hc3000 wont start
this is a problem in your power board.
thi unit is getting OFF due to heating problem
Jun 29, 2008 | Mitsubishi Office Equipment & Supplies
How do i shut off hot service light and cool the burner
Good Afternoon Friend,
I understand you want to know how to turn the "Hot" service light, and cool the burner on your Frigidaire cooktop, model# GLEC30S8. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any burner. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire 31 in. GLEC30S8 Electric...
Fan not running in freezer
Good Morning Friend,
I understand the fan is not running in the freezer portion of your Frigidaire refrigerator, model# FRT21P5A. I see that the freezer is getting cold but the fan does not circulate the cold air. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and listen for the fan to circulate the air. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRT21P5A Top Freezer...
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Fan doesn't come on
First is the blower motor casing hot to the touch? If so, the motor is probably bad, capacitor good? If the blower isn't running the burners will shut down due to overheating. You could have a dirty flame sensor, circut board problem or loose/bad wire connection.
Nov 21, 2009 | Intertherm Heating & Cooling
Acer 4420 shut down, will not restart
Allow heat to dissipate.
Clean vents with air compressed (on power off only)
Use fan support for laptop if you use CPU intensive application in hot environment or if air circulation is not optimal (on soft support, on your knees etc)
Jan 10, 2009 | Acer Extensa 4620 Notebook
Nov 23, 2008 | Heating & Cooling
150000 1974 national gas forced air furnance does the fan come on the same time the gas comes on. ...
not familiar with that particular model but on virtually every type and style of furnace i have worked on in the last 21 years. the fan is delayed. usually the burner lights then 3 to 5 minutes later after the heat exchanger has gotten nice and hot the fan comes on and blows nice and hot air. on old furnaces there was and is a switch usually on the upper right side of the furnace bulkhead that has a spring like device that heats up and rotates till it makes a set of contacts that turn the fan on. if it gets to hot the set of contacts breaks the power to the gas valve and shuts down the burner. as the furnace cools down on shut off there is a third set of contacts that open to turn off the fan so you don't get a draft. sometimes the stat can be wired up wrong, and it will bring the fan on right away ,and air will be cool and drafty till furnace catches up.
Nov 12, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
