Can 2 wireless routers be connected wirelessly together no cable
I have a comtrent want to put one upstairs for stronger wireless can it be done with out running a ethernet cable.
    Sergeant:
  • 320 Answers
In short, the answer is yes.
However both routers need to support what is knows as WDS (Wireless distributed Network)
This allows multiple routers to connect together to extend the signal of a single wireless network.
The steps change from one router to another, but in general you will need to log into one routers web interface (usually by first plugging a hard wire into the router then into your computer. Then open a web browser and put http://192.168.0.1 or 192.168.1.1 in the address bar)
Default username / passwords are usually admin / admin unless you have changed them
Next goto the wireless section and set this first router up with the wireless name and security you wish it to have.
Repeat this on the second router, but this time you will need to goto wireless and look for an option that says "Enable WDS"
Some router have a "Survey" option, this will bring up the wireless network the router can see and allow you to easily select which network you want to connect this router to.
The one big step is to make sure the second router is setup the same as the first, you will need to make sure it is named the EXACT same, and also is using the same wireless password as the first.
In some cases you may want to disable DHCP on the second router, but this may not be necessary, so testing with DHCP on may be your first options.
Test the connection while the routers on are the same floor to start, this will save time going up and down stairs if settings need adjusted.
Also keep in mind wireless signal goes outwards from an antenna, so having one upstairs and one downstairs you may still see low signals, In some cases you can adjust one antenna on each router to lay flat instead of pointing up in the air. This should only be done on one antenna on each router if signal is too weak. It does not always help.
Hope this gets you started, feel free to provide model information for your router(s) if further help is required.
Posted on Nov 18, 2014
  • 14 Answers
SOURCE: Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Posted on Dec 06, 2007
  • 556 Answers
SOURCE: two routers US robotics connected together
It appears you may have confused the world because of your IP addressing choices. Do you know what a subnet mask is? It determines which machines share the same network with other machines. Routers by design are the connection between different subnets, Most routers default to 255.255.255.0 for the subnet mask which means both of your routers are in the same subnet as they are 192.168.2.? meaning you have two separate networks sharing the same same subnet address when they should be unique. Try making the wireless router 192.168.3.3 or 192.168.3.1. This puts devices in your wireless network on the 192.168.3 subnet and the devices in the ADSL subnet in the 192.168.2 subnet which includes the WAN half of the wireless router. I believe this will correct your network issues. In this case if hardcoded the gateway for the wireless router would be 192.168.2.1 also known as the the adsl modem
One Piece
  • 53 Answers
SOURCE: connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Posted on Apr 14, 2008
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is deafjrt@aol.com
Posted on Sep 17, 2008
Geekman
  • 32281 Answers
SOURCE: WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Posted on Dec 26, 2009
How to connect a linksys e1500 router to a repeater?
Run an Ethernet cable from one of the LAN ports on the downstairs router to connect to the WAN port on the upstairs router. Result: 100% connection.
Jul 08, 2012 | Linksys E1500 Wireless-N Router with...
So I really need help. I have a Linksys (WRT54GS) wireless router upstairs connected to the internet, printers, etc. and a Netgear (WGT624) downstairs connected to a desktop, xbox and laptop. I don't want...
More information is needed.
Is the 'WAN' port on the Netgear router connected to anything?
(cable-modem? DSL-modem?)
How many friends will come over at the same time?
How many 'LAN' ports are on the Linksys? How many ports are "free" ?
How many 'LAN' ports are on the Netgaear? How many ports are "free" ?
How many "spare" Ethernet cables do you have?
Is your goal to provide computer-to-computer connectivity,
or are you just trying to provide Internet access for everybody?
If you are "downstairs", is the wireless signal from the "upstairs" router strong-enough to provide wireless coverage "downstairs"?
If you are "upstairs", is the wireless signal from the "downstairs" router strong-enough to provide wireless coverage "upstairs"?
Jan 04, 2010 | NetGear WGT624 Wireless Router
I have F5D7230-4 router. Modem downstairs connected to DSL. Computer upstairs needs a wireless card to work This is a ''G'' router, but it only picks up signal upstairs with a ''B'' card which I stole...
The Belkin F5D7230-4 router should offer "Wireless G" connections,
unless you have used its built-in web-interface to only allow "Wireless B" connections.
So, if your "upstairs" computer, with a "Wireless B" adapter, connects, it will connect only at the slower "Wireless B" speed.
If you want "Wireless G" speed, you will need to purchase a "Wireless G" adapter.
Nov 18, 2009 | Computers & Internet
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Problem connecting to my network
What I would do is replace the wireless router with a 4 or 5 port switch to control computers (devices) downstairs. Or, if you need wireless access, purchase only an access point to cover downstairs.
This way the wire from upstairs goes directly into the access point and you have wireless access downstairs.
And yet another way would be to purchase Airlink 101 PowerEthernet boxes ($54.99 each) and use those to connect an access point anywhere in your home that has an outlet.
Nov 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Cable modem
Go and buy a router. Plug your existing modem into the WAN port and your computers into the LAN port. You could even get a wireless router and connect your upstairs computer wireless. Be sure to lock down your SSID (Wireless Access Point Broadcast Name) so your neighbors or people driving by don't get on and do bad things on your network.
May 31, 2008 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
