How to open the door of wasching machine Hotpoint Ariston AQD970F 49 EU
SOURCE: Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Posted on Jan 21, 2009
  • 10 Answers
SOURCE: we have the Ariston Margherita front loader
if the machine is full of water pump blocked or broken if machine empty needs new door interlock or pressure switch blocked or broken
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Posted on May 17, 2009
  • 9 Answers
SOURCE: door open light keeps flashing
faulty door lock (part no INT51)
Posted on Jul 30, 2009
barkencoa
  • 3463 Answers
SOURCE: Door lock broken on Ariston Washing machine
Remove top cover, tilt washer backwards, and force door lock from inside with a long screwdriver or similar, you will break the lock, so have a new one ready to fit
Please rate my solution.
Thanks.
Posted on Sep 05, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Thanks.
Posted on Sep 13, 2009
Need part number for door glass replacement Ariston ARWDF129NA
it is the whole door and glass. C00277532
check this link http://r.search.yahoo.com/_ylt=AwrBT8FtQthU9zQASwhXNyoA;_ylu=X3oDMTByMG04Z2o2BHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkAw--/RV=2/RE=1423487725/RO=10/RU=http%3a%2f%2fwww.guaranteedparts.com%2fpicture_library%2fAriston%2fARWDF129NA.pdf/RK=0/RS=MKzVwRgG.yYF8eJHJVxrlf8MM_U-
Feb 06, 2015 | Hotpoint-Ariston ARWDF129NA Washer
Door locked,cant open
just get an old door from any ariston..hotpoint or indersit machine make sure it is the same size
Jan 12, 2014 | Ariston Technologies Ariston AWD12 Front...
How do I stop cycle and unlock door?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 27, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Door won't open
if you can still see water in the machine, check the drain hose. If there is no blockage or kink, try to drain machine by lowering the drain hose below the machine level. Once the water is gone, door lock should release.
Mar 28, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My aqurius WD420 shows that the door is locked. So i can't open it........
If the door will not open normally, then the only solution is to remove the top cover, and force the door open from inside the washer at the front
Jan 17, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door latch broken
Look in yellow pages if you are in the U/K, and ring Hotpoint service, who are the service agents for Ariston.
Thanks.
Jul 19, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
