Sony Bravia kdl-52w3000 location lamp bulb on tv
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
It is inside its light engine. Electro help
Posted on Nov 18, 2014
HDTV GURU
  • 261 Answers
SOURCE: Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Posted on Feb 01, 2008
  • 197 Answers
SOURCE: My Sony Bravia KDL-52W3000 panel is broken. Does
there are diferent versions of panel
Posted on Jul 02, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 148 Answers
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Posted on Feb 03, 2010
  • 8457 Answers
SOURCE: tv turns on has sound
Have flashes of picture about 30 sec, or so?Than the 2 long LCD inverter boards are dead,have backlight make no difference.Tries to reset the tv back to factory setting by,unplug,replug the tv and cable box back about an hour later,let the tv Tuner board to reset it self,the cable box upgrade it softwares.After this,u still have the same problems,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes LCD inverter boards or the Tuner board for the replacement.
Posted on Jun 24, 2010
Where is the lamp bulb located on Sony kdl-52w3000
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Try this site too. Electrohelponline
Nov 17, 2014 | Sony XL-2100U Projector Lamp for...
Where can i get a main board for my sony bravia kdl-52w3000 tv
I would try shopjimmy.com, or tvpartsguy.com, or from one of Ebay's reputable online sellers.
Sep 02, 2012 | Sony BRAVIA KDL-52W3000 52 in. LCD...
The picture is too big for the screen and i can't get it reduced
Change aspect ratio of screen through screen format option in Menu.
Hope this will fix your screen size issue in Sony KDL-52W3000 tv.
Thanks.
Dec 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony bravia kdl-52w3000, turn tv on, no picture or
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
52 in sony tv plasma i turn it on an it comes on
Sounds like the lamp is burning out, hopefully it's a replacable type.
Mar 29, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
