Question about Radio Communications
<!-- from fixya rte -->How do I reconnect Bluetooth to Phone. - Radio Communications
  • arnoldo880
    arnoldo880 Nov 21, 2014
    Hi Dorothy Spinks, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What kind of phone do you have and what are you trying to connect it to?
2 Suggested Answers
SOURCE: need passkey to reconnect bluetooth
Use this link to get installation instructions! http://web.jabra.com/JabraCMS/NA/EN/Misc/GettingStartedBT350
Posted on Jun 22, 2007
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
My bluetooth light shines blue on my cellphone,the phone says bluetooth is connected,but the headset does not appear to function,,,,it worked an hour ago just fine ,,,,i could not find any instructions for...
the bluetooth device battery is it charged and is it ok,if you live your phone very there is a distance limit then it goes on standby for a limited period then it automatically switchies off
Jan 20, 2014 | Naztech Noisehush N700 OverHead Bluetooth...
I am trying to disconnect my bluetooth from my old cell phone and reconnect it to my new cellphone
Unable to connect my new iphone to the bluetooth in my car.
I've turned off the blue tooth in my old phone but it only turns off the bluetooth in the car. I have tried to then reconnect my new iphone, which is searching and showing that it has located the bluetooth (blue tooth flashing in car, shows on the sceen for a second and then turns off with message 'no service' phone off. If I turn on the old phone, everything comes back on.
Any ideas?
Jan 23, 2011 | Motorola Mobility Bluetooth Hands Free...
My mobile phone was answered in the car by a friend, who pressed the "answer" button on the phone instead of the "answer" button on the car's bluetooth system. Everything locked up. I...
Try disconneting the car battery and leaving it for about 30 minutes, then reconnect it and try again.
Be warned though that if your head unit has a security code, you will need to make a note of this before you disconnect the battery as you will be asked to re-enter it when you reconnect the battery.
Carl - www.carheadunit.co.uk
Oct 30, 2010 | Car Audio & Video
I have a plantronics bluetooth. I'm not sure of the model. After I talk on it sometimes the bluetooth will peep and seems to disconnect from my voyage phone but the bluetooth stays on. I hit the call...
Install Nokia Phoniex in your computer and attach handset.
1. detect device 2. click on device information and print it. you got answer
Jul 01, 2010 | Cell Phones
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
1 Enter Pairing mode.
• Turn off your headset and press and hold the Multifunction
button until the blue indicator light remains lit
after blinking.
• If you turn it on for the first time, it proceeds into Pairing
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will
flash 10 times rapidly before entering Standby mode.
• If the blue indicator light remains lit, retry pairing.
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
Jan 03, 2010 | Samsung WEP350 Bluetooth Headset Red
Nokia E75 bluetooth disconnects and then reconnects
if your phone is under guarantee contact nokia care
atul jain
atuljain.webs.com
Oct 09, 2009 | Nokia E75 Cell Phone
Bluetooth module not attached
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jun 27, 2008 | Motorola Mobility H500 Wireless Headset
Bluetooth Mouse problems
There may be wireless interference. Do you have a bluetooth cell phone?
May 01, 2007 | Logitech V270 Mouse
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
