Question about Plumbing
Hot water is leaking from the spout of Banbury ca87000 sink
    New Friend:
    Problem Solver:
  • 11 Answers
The filter on the tip is clogged and loose
Posted on Nov 21, 2014
  • 148 Answers
SOURCE: Bathroom sink ''mixer tap'' leaking internaly.
if your valve is single handle there is usually a small
button type of cover for (sometimes rubber the size of a pencil erasure) that covers acces to a hex key screw that you have to remove to remove the handle
once you have removed the handle you will need a large adjustable wrench to turn a large nut that holds the cartridege tighten if still leaks remove and replace you can math the assembly at HD or Lowes
Posted on Dec 30, 2008
sledge1863
  • 149 Answers
SOURCE: leak at spout pivot point on Kohler K-378 traditional kitchen fau
Not going to stop the leak by tightening. Go to local plumbing or home store and they make a repair kit that has the pieces to fix your problem. Also has a diagram on the back of the kit to guide you, its really an easy fix, shut off water under the sink, both hot and cold,and just remove the handle and unscrewing the top of the valve assembly. Good luck dont forget to rate.
Posted on Mar 30, 2009
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 82 Answers
SOURCE: I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Posted on Sep 03, 2009
  • 94 Answers
SOURCE: water leaking from tub spout when shower is on
yes they do,part #1224
Posted on Apr 27, 2010
Which is the good single handle sink faucet?
Eyekepper is a good sink faucet. The sink faucets come with Matching Esutcheon Cover Plate Chrome and many other amazing facilities. The faucets provide both hot and cold water and it comes with a lifetime breakage warranty and 30 day money back guarantee.
Specifications
  • Color: 6009-Chrome, Chrome
  • Finish: 6009-Chrome
  • Mounting: Deck-mounted/ Single hole
  • Number of holes: 1
  • Handle/ Lever placement: Centerset
  • Number of handles: 1
  • Main Body Material: Zinc Alloy
  • Spout reach: 3.1 inch
  • Spout height: 5 inch
  • Overall heights: 6.3 inch
  • Water Mode: Waterfall
  • Water Feature: Mix Hot and Cold
  • Water Pressure: Minimum 0.5 bar, 1.0 bar recommended
Pros & Cons
Pros
  • Beautiful design
  • Inexpensive
  • Convenient
  • Easy to install and use
  • Fine quality
Cons
  • Noisy activities
Apr 02, 2018 | Plumbing
How do I fix hot water handle that is leaking on Moen Banbury ca87000 sink
The valve cartridge needs replaced. Those can be purchased at most home improvement stores, such as Home Depot. Or, it may be under warranty.
http://www.moen.com/replacement-parts/search
Nov 17, 2014 | Plumbing
Vessel sink
Hi, I presume you mean that the water spout is dripping when the taps are opened, remove the spout (it either unscrews anticlockwise using a tool or pulls up with force) , at the base is a o-ring that needs to be replaced, obtainable from local hardware store.Hope this helps. Don't forget to rate this help.
Oct 14, 2013 | Home
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
Faucet leaking at tee where hot and cold connect to spout
The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
source Best Kitchen Faucets
Feb 03, 2012 | Kohler Fort© Widespread Lavatory Faucet...
I replaced the cartridges in my moen kitchen 2 handle faucet.I used danco 6s-1h/c. the hot side works correctly. the cold side just dribbles out. no idea how to solve this one.
by dribble out I guess you mean that the water is not flowing out the way you want?
first thing I would do is remove the coldside cartridge and test the water flow to that point. If the water is free flowing ( yes its a bit messy) use a second person one to open the valve ubder the sink the other to cup over the top of the open side of the faucet.
if that has good flow then while the cold is still openhold you hand over the spout and turn on the out water to us that to back blow the tube that goes to the spout.
Hope this works out for you best of luck
Tom
Sep 12, 2011 | Moen Banbury Collection 2 handle Kitchen...
Leak at spout pivot point on Kohler K-378 traditional kitchen fau
Mar 30, 2009 | Plumbing
Leaking Kitchen Tap
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Dec 30, 2008 | Home
Plumbing Logo
51 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
