Question about Lavazza Espresso Point Capsule Machine
Lavazza espresso point. Water leack into the bottom tray. what seals are needed to fix it and how?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
It's the rubber ring in the group. From over heating.
Posted on Dec 11, 2014
SOURCE: cold espresso
it may be the the back fuses not working or the two thermostat are not working good, or the worst possibility can be the electronic card.
Posted on Apr 29, 2009
  • 10 Answers
SOURCE: Lavazza point espresso machine no steam
Sounds like a clogged steam pipe or a jammed two-way valve. First, I would try unfolding a small paper clip and then stick it up the spout of the steam pipe. if this does not free up the steaming arm then it is most likely a clogged two way valve. Should you need service you can call 781-393-2929. we are an authorized lavazza distributor and service center
Posted on Aug 25, 2009
SOURCE: LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
Help
Posted on Sep 29, 2009
  • 19 Answers
SOURCE: Lavazza Espresso Point Matinee
Take the wand off and run a small thin paper clip thru the hole in the tip contact me at www.lavazzarepair.com
Posted on Oct 13, 2009
  • 19 Answers
SOURCE: My Lavazza Espresso Point Capsule Machine dispenser dry!
Sounds like you need a pump contact me www.lavazzarepair.com
Posted on Nov 12, 2009
I have lavazza expresso pointe machine. I put in cartridge and select cup size and water keeps going. It doesn't stop so cup overflows and ends up just water flowing thru
need to remove the back cover, which has a few screws in the bottom left corner is a round and white plastic device that is said meter. Disconnect hoses from it and open it. Clean it well and then close it and put in place. Should be fine!
Jan 06, 2014 | Lavazza Espresso Point Capsule Machine
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza coffee maker does not recognize that it is filled with water
A small water sensor needs to be replaced, you can pick one up, from sovrano, or a supplier pretty easily,
Apr 29, 2008 | Lavazza Espresso Point Capsule Machine
Leakage when filling espresso cup
I had the same problem, there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round. Replacing it with a seal from the hardware store corrected my problem...GOOD LUCK!
Mar 10, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
554 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
