Question about GE Washing Machines
How to replace seal of ge top load washer
My GE washing machine model No. PTAN9455MGG is leaking when we add water it start dripping I can hear sound. I think I cant open from sides. Only from top or bottom. Please inform me how to replace seal and from where I can find new seal. I have already clean the drain pump and checked all hoses and found ok no leakage on hoses.
  • GE Master
  • 2,963 Answers
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Posted on Dec 21, 2014
  • 159 Answers
SOURCE: Water Leakage Under Front Load Washer
most likley cause of your problem is the grey bellows has a tear in it. Inspect the bellows to check for tears. Or you can remove the lower panel and run the washer and look for the leak that way. Im sure it is a tear in the belows. Not a diffacult part to replace if you are mechanicly inclined. Good luck.
Posted on Jul 12, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
Bgillespie
  • 89 Answers
SOURCE: cracked discharge hose on GE washer
Are you sure thats the model number? Im having trouble finding it on my end???
Posted on Dec 17, 2007
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
I have Kenmore elite washing machine model: 11045088401. It started leaking water from the drain pump. How would I fix it?
If u have seen the water leaking from the pump the only fix is to replace the pump..
Dec 13, 2012 | Washing Machines
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
What is F3 error on GE Washer Model Ptan9455mgg
How do I know? Go to the web site or your manual to find out the significance of the code so you can then intelligently address the issue. Doesn't that make sense?
May 30, 2012 | GE Washing Machines
My GE top loader leaks at the spin cycle when it is letting out the water
Sounds like the tub seal under the tub where the transmission goes into the tub. Replace the trans and seal.
Mar 15, 2011 | GE WBSR3140DW Top Load Washer
My washer sounds like it is leaking but no water on floor but you can hear water dripping inside even when the water is off
Most likely the water valve is stuck open...Post the model number and or call 877-293-1739 and i can help you out with ordering etc...
Mar 13, 2011 | Hotpoint Washing Machines
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
How do you open GE washer model WJRE5550H1WW? When my washer adds water, some of the water drips down towards the bottom of the machine.
on the front panel under the lid/top piece are two clips use a screw driver to push trawards machine and it will bring front panel towards you and unhinge piece wala! all exposed
Oct 01, 2009 | GE Washing Machines
Washing Machines Logo
123 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
