Question about Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Weighted Keys, 128 Programs, 64 Split Polyphony, Split Layer, Setup Mode, 24 Bit DSP Technology, Black
How do I find setup software for Emotions Marie embroidery machine?
I have the machine and it works but will not connect with my computer because I do not have the setup disk. i have the machine
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Maybe you can mail the factory or search for the type plus driver on google
Posted on Nov 26, 2014
What do i need to test my roland TR77 drum machine
Midi out to computer with software and basic knowledge on how to work it.
Jan 18, 2015 | Roland Music
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I brought a akai mpk mini and when i plug it into my laptop, the sony vaio ns-series VGN-NS30E says i need driver software to use it. the keyboard works on my computer though (dell volstrom 220 mini...
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
Jan 29, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I just bought the Vestax typhoon but everytime I go to the setup wizard in Traktor it says controller not connected and I'm not able to use the controller
Make sure you have loaded the right driver for this and the operating system is allowed. Vista and later sometimes won't work unless you have compatible drivers.
Jan 04, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
I have the yamaha dtexpress and a midifase conect but cant get anny sound to the computer??????????????
try a midi loopback device or a viruual midi cable such as sonys virtual midi cable: http://www.johnrofrano.com/tutorials/virtualmidirouter.htm
i dont know if this one will work, you could also search for loopb1 and hubi's midi loopback device, one of these should work.
what you have to do is use one of these programs, or something similar, to connect your midi input to the soundcard's midi wavetable or to your midi/synth/sequencing software's midi input.
also, the drum machine should be set to output to midi channel 10. make sure that your software is set to recieve on midi channel 10, if applicable.
Nov 29, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
I've recently purchased the NI USB Guitar Link, which comes with two Behringer discs. I'm having problems installing the Behringer iAXE (volume 3) software. Couple of things to share: 1. When I attempt...
If you get beyond the 32/64 issue, check the audio setup for your audio device in your windows control panel. If your USB interface both recieves from your guitar and sends audio to your external amp, make sure BOTH the input and output to the USB are listed as the in and out in the "VOICE" tab when you go to the control panel and "Sounds and Audio device properties".:
Nov 22, 2010 | Behringer VT250FX Virtube Guitar Combo...
My pa 800 cant link with pc....device driver software was not successfully installed !
Read the installation instructions very carefully.
OFTEN these devices need drivers installed that sometimes must have the USB cable connected, other cannot have it connected while loading.
I have even found some that one has to install while in "safe mode".
ALSO verify that you have the operating system in your computer that is required... Often older software will not work with Vista or Win 7.
May 11, 2010 | Korg Pa800 Synthesizer
It doesn't record from instrument input , it records only from the microphone of "apple mac"even if we make all that the manual describes
You likely have not got the driver installed correctely. In Windows type machines OFTEN you must install the software driver BEFORE the device is tied to the computer. It sounds like you are on an Apple machine. Look for cautions regarding connection before software is installed.
Apr 05, 2010 | Lexicon Lambda 4x2x2 USB Audio Interface
Recording my voice through computer with keyboard
You need a Sampler. Either software or Hardware will work. A sampler is the device that will make it possible to play your voice on your keyboard. There are many software samplers available, take a look at websites like sweetwater.com or musiciansfriend.com and have a look at the pc software section. You will also need a MIDI connection for your computer to enable the keyboard to talk to your computer (runs around 50 bucks). I would look at a program like Sampletank or others.
Dec 05, 2008 | Music
Open Questions:
See all Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Questions
Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Weighted Keys, 128 Programs, 64 Split Polyphony, Split Layer, Setup Mode, 24 Bit DSP Technology, Black Logo
46 people viewed this question
Top Kurzweil Music Experts
drivealot
john cordey
john cordey
rhodesworks
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
