Question about Avanti WD29EC Water Dispenser - Tabletop Cooling Dispenser 5gal 15.25" x 10.75" x 12" White
How Can i fix my dispenser that is not powering up even when plugged in the outlet?
The dispenser stopped working. Its not powering up nor running. The lights are not coming on
    New Friend:
  • 15 Answers
Get rid of it and instead install a filter system ( double or reverse osmosis) under the counter.
Posted on Nov 28, 2014
My upright Frigidaire freezer stopped running. I have checked the outlet and it functions just fine. The light doesn't come on, no controls work makes no noises. Acts like there is no power to...
Hello Ed Greene, thank you for your inquiry!
I see that your Frigidaire freezer is not operating. You explained that the outlet is working and the lights or controls are non-operational. It sounds like a potential issue with the power cord or control panel within your freezer. It would be best to have a technician come out to the home to review the freezer to diagnosis the correct problem and replace parts as necessary. This will help avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Dec 12, 2014 | Frigidaire Freezers
Freezer in unheated garage stops working
Check connections from your power outlet to your fridge. If the motor is not running check your thermostat. if not working check your compressor motor.
Feb 10, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
Jan 27, 2013 | Magic Chef Chest Freezer MCCF5WBX
I HAVE AN EXTENDED WARRENTY ON MY FREEZER,IT STOPPED WORKING AND NO ONE ANSWERES AT FRIGIDAIRE ON SUNDAYS WHAT DO I DO I NEED AN AUTHERAZATION NUMBER TO CALL FOR REPAIRE
make sure the outlet has power. maybe plug a lamp or something into the outlet and see if it works. you may have tripped a breaker
i know know anything about contacting refrigidaire. good luck
Sep 09, 2012 | Freezers
Kenmore freezer model C10BLEM blows circuits. I just bought it used. At original owners it worked well. I plug it in and after a couple of minutes it blows the circuit. I plugged it into the furnace...
If it is a chest freezer, almost certainly it is the compressor. Only way to check is to pull the power plug out then remove the compressor wires from the terminals then make sure it doesent touch the frame of the freezer, then plug the power back in and see if the power trips again. If not, there is the problem.
Aug 22, 2011 | Kenmore 22.7 cu. ft. / 643 liter Chest...
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
Jul 08, 2011 | Danby Freezers
My Magic Chef 5.5 cubic chest freezer with manual defrost, just quit working. It was a year old this March and it stopped working this July. The power light is on, but run light is not. We unplugged for 5...
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
Oct 30, 2017 | Magic Chef Chest Freezer MCCF5WBX
I have a frigidaire fridge freezer. Its about 3 yrs old and has stopped working. I have done all the usual like checked the fuse. Before it stopped working had moved it across the kitchen..has moving it...
Hi!!
Did you plugg unit back to the wall outlet?? Is that outlet working??? Did the plug got damaged when disconnected?? Check unit's power cable for continuity. Check freezer temp. controls.
You can plug and unplug your unit as many times as you want an you should not have any problems.. Check the above mentioned items, I think it is where your problem resides.
Don't forget to rate this post!! Good Luck!!
Jul 04, 2010 | Freezers
My chest freezer has stopped working . kelvinator H150H*13. I switched it off as it was not being used, then switched it back on again 2 weeks later but its not working at all. The light does not come on...
If the light isn't even coming on, check for voltage at the outlet. If that is good, check the bulb in a lamp or drop light. If both those check out, then the fun starts.
Could be that the thermostat is stuck (rusted) in the open or off position.
Mar 03, 2010 | Freezers
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Avanti WD29EC Water Dispenser - Tabletop Cooling Dispenser 5gal 15.25" x 10.75" x 12" White Logo
Top Avanti Freezers Experts
Dennis Boxerman
tom wright
tom wright
richie46
Are you an Avanti Freezer Expert? Answer questions, earn points and help others
