Question about Toshiba Computers & Internet
I have a toshiba satilitte c655d -s5120 i accidently pulled the power switch cable off the motherboard
    Top Expert:
  • Toshiba Master
  • 14,161 Answers
if you need anymore help let me or someone here know.
Posted on Nov 18, 2014
    Top Expert:
  • Toshiba Master
  • 22,107 Answers
It can be refitted, ask a computer tech with experience to repair it for you.
  • 265 Answers
SOURCE: I would just like to know the location of the bios
Hi ,
why do you need to know this , its somthing that you should not have to touch , I have the same unit you do so I can tell you its under the cover on the bottom side of your laptop .....it will be marked bios on the chip ..........goodluck Roy
Posted on Jul 19, 2011
  • 265 Answers
SOURCE: where is the bios chip located on a Toshiba laptop
Hi ,
The BIOS chip is located near the usb ports , I should tell you its a non removable chip ....
Goodluck Roy
Posted on Jul 22, 2011
electron-man
  • 136 Answers
SOURCE: i need toshiba c655d-s5063 motherboard
if you lost your restore cd's please try here:
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=481385
Posted on Aug 24, 2011
Geekman
  • 32281 Answers
SOURCE: toshiba c655d battery not charge
The motherboard maybe damaged beyond repair because you only see broken tracks on the top layer and most likely other circuit tracks are broken in the other layers on the motherboard.
Posted on Oct 16, 2012
Testimonial: "My thoughts exactly, I'll have to buy another motherboard...thanks"
My Toshiba Satellite c655d web cam says locked by another program, how do I fix it?
check the anti virus or your windows firewall,if they are not the cause,uninstall suspicious pro
grams...
Sep 28, 2013 | Toshiba Satellite C655D-S5120 Notebook
Keyboard wont work
Have you been to the repair center yet?
Jan 24, 2013 | Toshiba Satellite C655D-S5120 Notebook
Toshiba c655d battery not charge
Oct 15, 2012 | Toshiba Computers & Internet
Why is my toshiba satellite c655d-s5200 screen is black and i can faintly see
Okay. Got a bright flashlight, and some tape?
OH I'M JUST KIDDING!
Primer;
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
Light Emitting Diode.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch. Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 11 photos ]
A screen Inverter converts the power from the laptop, for the LCD screen.
The Toshiba Satellite C655d-s5200 uses LED's for the Backlight, and No screen Inverter,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~C655D-S5200/
Which narrows your problem down to two possibilities;
A) Problem with the video cable
B) Problem with the LCD screen.
I state LCD screen, because you won't be replacing the LED backlighting. You have to buy the entire LCD screen assembly, as shown in one example above.
(Example is shown for reference, not advertising. You may find a better deal from a reputable dealer, also)
Video Cable:
The Video Cable is attached to the motherboard, under right about at the number 6 key, on the Keyboard.
It then goes across to the Left Hinge, and up into the Display Assembly.
From there it goes to the back of the LCD screen.
From everyday normal opening, and closing of the laptop over time, the video cable may become pinched, and pulled on.
This can create a loose connection at the motherboard side, and/or LCD screen side.
It can also cause damage to the video cable. If the sheath of the video cable shows visual apparent signs of damage, the wires inside may be damaged also. (Stretched/Broken)
Laptop off, ALL power removed, (AC adapter {Charger}, and Battery), I suggest checking the motherboard side connection first.
A visual inspection will Not do. You need to physically see, if you can plug the motherboard side plug of the video cable, into the connector on the motherboard.
A loose connection that is not apparent to the ***** eye, is all it takes to have a problem.
You can click on any photo to enlarge,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-2.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-3.htm
Stop on Step 22. Access to the motherboard side of the video cable.
A word on the Keyboard Cable, and it's connector on the motherboard; (Steps 9, 10, and 11),
The Keyboard Cable stays with the Keyboard. It removes from the motherboard connector. The Keyboard Cable has NO plug, or connector on the motherboard end.
The Keyboard Cable is a FFC. Flat Flex Cable.
It has flat gold plated contact strips on the motherboard end.
The motherboard connector is a ZIF connector. Zero Insertion Force.
In Step 11 you can plainly see this connector.
Has a large white rectangular BODY on bottom.
The smaller rectangular shaped piece on top is the Locking Bar.
The Locking Bar does NOT completely remove from the Body.
If it does it is broken, and means motherboard replacement.
Hence why I am being so detailed.
I am sure you use great finesse, but wanted to advise you in advance of the 'danger'.
The Locking Bar is moved towards the LCD screen, and as advised about 1 millimeter. ( -> O <-)
There are Tabs on the Locking Bar. One on each side. Usual procedure is to use your thumbnails on these Tabs, and ease the Locking Bar forward.
Now gently tug on the Keyboard Cable. You may have to gently move it side, to side, to break the Keyboard Cable loose. They sometimes get stuck over time.
Pretty stiff? Better check to see if you have the Locking Bar fully unlocked.
The Keyboard Cable MUST go back in the same position, and through the same plastic Latches and Channels.
(As do all the cables, or you may pinch them, and also will not be able to get the laptop back together correctly again)
Make a mark on one side of the cable, (Away from the gold plated flat contact strips), and a matching mark on the ZIF connector of the motherboard, if you need to.
You can slip the Keyboard Cable back in, Ram Memory, DVD drive, and Battery, and reconnect the AC adapter, to see if this was the problem.
Still no?
Check the LCD screen side connector of the video cable. Is it tight?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A665-A665D-A660-A660D/remove-replace-lcd-screen.htm
LCD screen connected, turn the laptop on.
Was this the problem?
No?
Even if there are no apparent signs of damage, you may wish to take the video cable down to the nearest 'Mom and pop' computer store, and ask them to check it for continuity. This way you can see if any wires are broken inside. (Labor charge may be free to $5)
(My thinking is if you go to a large computer repair shop, they are going to want to repair the laptop, or sell you an LCD screen, or a new laptop. "Oh that old thing? For 2995 I can put you in the seat of this baby!" )
Or since the video cable is very economical, you may wish to just replace it.
Just one example from a quick search,
http://www.ebay.com/itm/Toshiba-Satellite-C655D-6017B0265601-LCD-Video-Cable-Genuine-OEM-Laptop-Tested-/290753862740?pt=US_Video_Cables_Adapters&hash=item43b247dc54
[Black end on right is motherboard side, gold colored end on left is LCD screen side ]
Video Cable ruled out your problem is the LCD screen, or to be more specific, the LED backlighting.
Replace the LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | Toshiba Satellite C655d-s5200 15.6" Screen...
Toshiba c655d - s5200 wont start up. i get a black screen that says no bootable disk
sounds like you have a bad hard drive,,try putting a bootable cd and start it like that,or at the start up hit the f2 key and go into the setup and seee if there is a hard drive loaded
Jun 12, 2012 | Toshiba Satellite C655D-S5120 Notebook
I am getting an error message that reads BOOTmgr is missing. I have a Toshiba Satellite C655D
Change the boot startup order back to the hard drive as the first boot device in the BIOS. If you still have this problem then -
Go to this WEB site to fix Bootmgr is missing problem.
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Mar 29, 2012 | Toshiba Satellite C655D-S5120 Notebook
Why is my brand new laptop satellite c655d-s5529 keep on saying toshiba mq01abd032 sata disk device the following hard disk are reporting failure
Take the laptop back "asp" you should not be getting messages on the screen, it indicates device issue and maybe a bigger problem.
Mar 07, 2012 | Toshiba Satellite C655D-S5120 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
