Question about Electrical Supplies
Need to wire a 621 fasco switch to outlet.need wiring schematic
  • 88 Answers
SOURCE: need wiring shematic for fog lights 2005 toyota corolla
im pretty sure these cars were already prewired for fog lights .there should be some plugs behind the bumper to fit them.if not get back i will explain how to wire them up.best of luck.
Posted on Oct 17, 2008
  • 250 Answers
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Posted on Jan 20, 2009
  • 63 Answers
SOURCE: how to wire combo switch
you should have 4 wires total (not including grounds, which get twisted together and connected to green screw) you have to know which is the power lead, and which goes to the light! 2 blacks, and 2 whites ...the 2 whites go together and connects to the silver screw, and the 1 black power lead goes to the gold screw, the other black wire(to the light) goes on the opposite side of switch above the silver screws on another gold screw
Posted on Apr 06, 2009
  • 10865 Answers
SOURCE: Installing a Leviton 5225 switch with outlet.
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Posted on Jun 02, 2009
SOURCE: need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Posted on Jun 22, 2009
I need a Fasco Model 621 Wall Switch For model 656 Vent, Lite, Nite Lite
Fasco has a number of different manufactures representing them.
You need the following:-
Fasco part # OEM part # Manufacturer
D1107 621 Universal Electric
Oct 16, 2017 | Fasco Heating & Cooling
Fasco d236 replaces 7190-1186 u90B1 - wiring cross reference?
Is this a water heater blower? Or HVAC?
Post question on water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
I do not have HVAC resources
Add a comment and say what you discover
Jun 28, 2013 | Water Heaters
Hello: I have a Levitron White decora 15 amp combination switch: I need to get a copy of the schematics as someone threw the schematics away... Geesh! Note The MFG part number is the same as the...
Hello.
There is no schematic shown online for that specific product.
Leviton shows a spec sheet on their website but no wiring schematic.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?sitex=10026:22372:US&item=8938
However the spec sheet does show the screw terminals on one side of device that indicate this is ordinary combo switch-outlet.
Open following link for illustration of combo switch-outlet:
http://waterheatertimer.org/images/Combination-switch-outlet-6.jpg
The problem that usually confronts people when they replace light switch with combo is that the combo requires additional neutral wire to power the outlet.
Neutral wires are the white wires twisted together and covered with wire nut that are pushed to back of electric box. Connect a short piece of white wire to the neutrals, and connect that wire to screw on combo device. If your electrical box does not have these neutral wires, you can get the outlet to work by using bare ground wire instead of white neutral, but I would never recommend this action as it violates national electric code and would not pass home inspection and would cause risk to electrician working on that same circuit who was unaware of a code violation.
Jul 23, 2011 | Leviton White Decora Rocker Switch &...
I need the schematic for a Fasco FIB 7C-16 fine wire upholstery stapler...and, if available, an owners manual. My stapler is not shooting staples and I have tried everything that is on the troubleshooting...
Hello from FASCO ITALY. Pls let us have yr complete email address and we will send you the manual and the schematics. Our email is fasco@fasco-spa.com best regards FASCO
Feb 12, 2011 | Garden
When turning on light there is a surge. Wanting to replace switch. Where would I be able to purchase one?
See if NuTone has a replacement part for that. Any of your local appliance stores, or Lowe's or the Depot should be able to help. FASCO! Yikes! Too many years with Fasco!
Jan 08, 2011 | Solar Fasco Model 621 Wall Switch For...
I need a wiring diagram for Fasco model #659 serial # 447621 ceiling fan, heater, light unit.
Yellow wire is light. Blue is vent. Red is heat element and fan after going through a circuit breaker and thermostat. Brown is night light. White is common to ventilator housing. Black is power to switch cluster.
Jan 25, 2010 | Fasco Dryers
Schematics on fasco air stapler #F1B 7C-16
I can e-mail you schematics. I have all Fasco & Rainco parts for this tool and more in stock!
Aug 10, 2009 | Fasco Staple Gun Pneumatic F3c Atw-38 Mod...
Need to find out how to wire a pilot switch to outlet
From what you say sounds like you just want to know you have 120v to the plug. In that case wire 1 end to dark and other to lighter color.
If it is a switch its a little differant. You have to know which terminal is HOT when the switch is on and wire ons side of lite to this term and the other side to nutural.
Usually pilot lights are not polarity sensitive so either wire to either line on teh pilot is ok UNLESS THE WIRES ARE MARKED. And you dont indicate that they are marked. IF THIS HELPDS PLEASE RATE ME & GRADE ME ACCORDINGLY. GOOD LUCK
Mar 03, 2009 | Honeywell Electrical Supplies
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
