My house heater turns off after reaching the set temperature but it does not come back up after that. In order for it to turn on I have to turn it off at the thermostat and wait about a minute them turn it on. What could be the problem
  • 183 Answers
If the thermostat is more than 5-10 years old, i would replace it. take the old one off the wall and notice the number of wires, then take that info to the store for the appropriate one. they are easily bought for $20 and up. sounds almost like it's short cycling, thinking it's warm enough when it isn't.
Posted on Nov 18, 2014
SOURCE: pro comm natural gas heater, pilot keeps going out
The problem is likely to be either the thermal-couple (easily replaced) or a clogged gas orrifice. The clogged orrifice would require a bit more know-how then the thermal-couple and with gas appliances it would be best to hire someone who knows what they are doing.
Posted on Mar 21, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a W355F Cozy wall heater. I lit the pilot
I would take out the new stat and return it.Just because it was new doesn't mean it didn't have a factory defect. I see this all of the time buying a/c and Heater parts that I have to return for credit.
Good Luck, Shastalaker7
PS It sounds to me like you know whats up.Sincerely, Shastalaker7
Posted on Nov 06, 2009
shastalaker7
  • 1515 Answers
SOURCE: my honeywell central heating system turns off on
Hi, Just to let you know I have repaired central Heat & Air systems for 33 years and Have seen this problem on many occasions. Lets see if I can save you so many trips.It says you have a programmable stat? On this stat and on a mechanical stat, they have what is called a heat anticipator that controls how many and how often your thermostat turns you're unit off and on and how long it cycles after the stat is satisfied. If you have ever seen under the cover of a mechanical stat, ( mercury switch type) you will see a dial with an arrow with numbers as .1, .3, .4 1.0, or .15 to 1.0 amps.Some are fixed and some are adjustable. On a digital stat, you will have to get into the program and see what the heat anticipator is set on. They come from the factory at .4, but to really find out what you'res should be it takes an amprobe to do this. The setting you need is what you're gas valve requires.I am sure I have lost you, but I am just giving you a little food for thought. If you can get into you're program and set this to .4, great. If the problem continues, your anticipator on this stat is more than likely, shorted, which would require you to buy a new stat.With a shorted anticipator, it will seem to be working like you say, but when satisfied, the temp.keeps falling until you reset power, then it fires and repeats this. Change the stat. If this is central heat and air, just follow red-rc which will have a red jumper to rh for heat, white to w, green to g=fan, and yellow or blue to y = cooling. If you have central heat only, you will find 2 wires red and white.Red to rh with jumper still installed to rc and then white to w.This is quite a long explanation, but I wanted you to know a little more then the next guy about your stat. Please let me know.
Sincerely,
Shastalaker7
Posted on Nov 12, 2009
  • 79 Answers
SOURCE: gas heater doesn't stay on longer than 5 minutes.
It sounds to me that your air flow is restricted somewhere. The first thing to check is your air filter. If that gets real dirty your restricted air flow will cause the hi-limit(hi temperature limit switch) in your heat exchanger compartment to over heat and open up your gas valve electrical circuit,thus, shutting off the gas to your burners. After the hi-limit switch cools down the furnace will go back to heating again then it will overheat again(you get the picture?) If it keeps cycling on and off like that the house will never get warm if it is cold outside. If your air filter is reasonably clean(you should be able to see light thru it easily) then the secondary heat exchanger could also be dirty, this is located above the indoor fan housing, you would need to pull the indoor blower assembly out of the furnace and look up above. The secondary heat exchanger looks similar to a radiator will fins. You can use a medium stiff plastic brush to brush the dirt,hair, whatever off of it. Another problem spot would be the cooling evaporator coil (if you have central airconditioning) located most likely above the furnace in the plenum(if your furnace is in a basement). This usually is difficult to access if an access cover wasn't installed when the airconditioning was installed. I would recommend an experience service tech to clean it for you. Also make sure all you supply air registers and return air registers are open . These are the things I would check first. Good luck!!
Posted on Nov 20, 2009
heatman101
  • 43501 Answers
SOURCE: Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 12, 2009
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Temperature control
Try this simple test
Turn the thermostat down to room temperature
If it turns off when you reach room temperature it means the thermostat is ok
Now if you place the thermostat back to 82 as you say you must have to leave it there until the warmth returns to the furnace thermostat
So it's either bloody cold were you are or your furnace is undersized
Dec 26, 2013 | Kitchen Ranges
I turn my heater on, it is set on auto, but it never turn off, it's a new thermostat.
If the setting was at 80 degrees and it didn't turn off, that's because the room didn't reach 80 degrees yet. Keep track of the room temperature as well as if it turns off when set for a lower temperature.
Dec 28, 2012 | Honeywell Programmable Thermostat Heater
The heater will not turn on until i move the thermostat
Moving the thermostat to a higher temperature is the way they are supposed to work. Then, once it reaches the temperature you have it set for and holds it for 5 minutes or so, it will turn back OFF. Then turn back ON, once the temperature drops below what you have it set on. It appears it's working normally, from what you described,
Mar 29, 2011 | Heating & Cooling
How do i change a 1996 ford explorer Limited thermostat?
The location of the thermostat for most vehicle.
Stand in front of the car with the hood open, you'll see a black hose hooked to the upper side of the
radiator.( about 2 inch in diameter, newer vehicles about 1 and 1/2 inch, and newer small cars
about 1 and 1/4 inch. ) Follow the hose to the other end, it connects to the thermostat housing. The thermostat is inside of the housing.( the hose usually goes to the air intake manifold, but some
housings are on the side or back of the engine. )
How to test the thermostat in most vehicles;
Make sure the heater is off, start the engine and let it run for 6 to 8 minutes, ( this will allow the
engine to reach, " normal operating temperature "), from the inside of the vehicle turn the heater
temperature on high and turn the fan speed on high.
1. Listen very closely for a click sound from the engine, ( most thermostats make a click when
they open )
2. Watch your temperature guage, it should begin to lower as the coolant starts to circulate.
3. Usually within a few minutes the radiator fan will kick.
To replace the thermostat in most vehicles yourself;
Remove the hose from the housing, then remove bolts from the housing and lift the housing off
to access the thermostat. Pay attention to witch side is up on the thermostat that you remove, the
new one will have to go in the same way. Also look at the temperature rating that is stamped into
the thermostat that you take out, and make sure the new one has the same temperature rating.
(failure to do so can cause false readings by some sensors, and may start triggering error codes)
Install new thermostat, right side up, put housing back on and bolt back down, hook hose back on
to the housing. Check the coolant level. Start the engine and let it run for 6 to 8 minutes to reach,
"normal operating temperature", and look for any leaking. before you turn the engine off turn your
heater wide open and listen for a click. Most of the time when a thermostat opens you can hear a
click and may hear the coolant flowing through the system. Shut the engine off, wait for it to cool
down and then check your coolant level one more time. ( do not fill all the way up, only fill to
FULL line on resrvior.)
I hope this helps you.
Feb 11, 2011 | 1996 Ford Explorer
Bad thermostat
If you want to double check the thermostat first;
they open )
Feb 02, 2011 | 1999 Ford F150 Regular Cab
Piolite light keeps going out after unit turns on and reaches temperature set on thermostat.
Check gas pressures standing and working make sure pilot burns correctly and thermocouple is in good order
Dec 13, 2010 | Empire DV-215 Direct Vent Natural Gas...
My gas furnace keeps will run until it reaches
Sounds like the Thermostat isn't resetting quickly enough.
Feb 17, 2010 | Heating & Cooling
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
